Just because I am curious.
Old Mar 12, 2024 | 10:38 PM
James Vining's Avatar
James Vining
Default Just because I am curious.
on the 2000 5.9 magnum Durango 4X4 can you drop the oil pan and replace the Oil Pump or do you have to remove engine or do some other sort of finagling to get the pan off Ie disconnect Motor mounts, tranny mount raise engine like a foot or more ?
I miss my 383 HP I could just unbolt the pump from the side of block if I wanted to replace it.
Old Mar 13, 2024 | 03:10 PM
You have IFS, and that front axle in there as well, so, my guess would be, you would at LEAST have to lift the engine some to get the pan off.
