2000 Durango AC leak at manifold
Old Apr 15, 2024 | 12:32 PM
Tucsontechie's Avatar
Tucsontechie
Default 2000 Durango AC leak at manifold
Hey guys, i hope this isnt a repeat but i didnt see it anywhere in the old stuff.
2000 D with 4.7 developed a leak between the compressor and the manifold (2 lines bolted to the compressor). This happened 2 years ago so rhe other day i installed a new desiccant canister and replaced the manifold line. Wouldn’t you know its still leaking from the same location, only worse now. Im beating my head on the wall here. Is there an oversized seal for this location or some other known fix im missing?
i have the ac charge manifold and vacuum pump etc to charge it correctly if i can fix this. The compressor still works great, id hare to drop $230 for a new one when a better seal would fix it.
PLEASE HELP! Tia
Old Apr 15, 2024 | 08:00 PM
Tucsontechie
PLEASE HELP! Tia
anybody at all??? I came back to check if this posted or not. Figured someone would have said something by now if it was posted correctly.
Old Apr 16, 2024 | 11:36 AM
You are in the right spot.....
Did you put a little oil on the o-rings before installation? Keep in mind, the a/c system operates under some serious pressure, and even the slightest nick in the o-ring will cause a leak.
Old Apr 17, 2024 | 04:18 AM
Tucsontechie
this vehicle doesnt have regular o-ring seals at the compressor. It has aluminum with the thinnest little rubber wiper. In my opinion its the dumbest “seal” ive seen in a AC setup.
Old Apr 17, 2024 | 08:31 AM
Not familiar with those, can you post a pic?
Old Apr 17, 2024 | 01:13 PM
Tucsontechie
basically like the ones GM used as well. These little useless things.
Old Apr 17, 2024 | 03:24 PM
Ah, I remember those.
If the ones you are getting are aftermarket, they may not be thick enough. They can't be real hideously expensive at the dealer... though, refrigerant ain't cheap.....
