No tail lights or dash lights 1998 durango
No. I can't.... I don't have a smart phone, and my camera died. I got mine from LMC truck. It is a simple install, unplug the headlights, the harness will plug into those, and then have it's own connectors for the bulbs. One wire to ground, (or, a couple...) on power feed, and you are done. I ran the harness to the passenger side along the top of the radiator. There is a convenient trough there on the trucks, with small studs I used to bolt down the hold downs I improvised. Works great.
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
No. I can't.... I don't have a smart phone, and my camera died. I got mine from LMC truck. It is a simple install, unplug the headlights, the harness will plug into those, and then have it's own connectors for the bulbs. One wire to ground, (or, a couple...) on power feed, and you are done. I ran the harness to the passenger side along the top of the radiator. There is a convenient trough there on the trucks, with small studs I used to bolt down the hold downs I improvised. Works great. ![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
I ended up finding a harness on eBay that says it fits my Durango so that’s nice 60 dollars for the harness new plug and switch pretty cheap fix if you ask me!
