Help with transmission codes
Old Sep 15, 2024 | 02:03 AM
Matt65737482's Avatar
Matt65737482
Default Help with transmission codes
So I have 2 codes p1765 and p0753
I have read this whole forum. My only difference is I don’t have any shifting problems it’s like it’s just in limp mode and takes a little to get up to speed. Before this I had a 6 volt battery draw and I had fixed that it was some aftermarket lights the guy installed. And i also had fixed my exhaust because it was cuz before the o2. So now i only have those 2 codes. My overdrive **** is broke off and it’s just the 2 wires and before if you clicked them to gather or just pushed one wire on metal override would turn on. Well now the wires aren’t touching or anything and it keeps going in overdrive and out of overdrive. Still no shifting problem just under power. I checked the relay and fuse there fine. I also did that pink wire trick and nothing happened. What do you suggest I do. This all happened after I plugged in a trailer lights for the first time. But same with the exhaust it had snapped causing it to be fully cut, that had happened on the way to get the trailer. I say all this just in case it has any correlation. I have owned it for a month now and drove is 400 miles just fine and now all this.
Old Sep 15, 2024 | 11:53 AM
Moparite's Avatar
Moparite
Did you read my post here? If it's shifting fine it may be stored codes. Did you try clearing them? Do they come back?
Old Sep 15, 2024 | 12:37 PM
Matt65737482
Yes I have, I also posted that same thing in that thread and no one replied. I also have reset the codes. I have a fancy autel ready screen that can test all the solenoids and all that. I just haven’t gotten around too charge it. I was just using a small hand held one to test it. I will use that and test my solenoids. But any help is needed.
in other words to codes do come back. Right when I turn it on after 10 seconds there back
Old Sep 15, 2024 | 03:10 PM
Need to check that 1765 code first. If the solenoids aren't getting power, they most certainly are not going to work.
