Oil pressure tanks after engine gets to operating temp.help!!
Old May 16, 2025 | 01:04 PM
  #21
STB4LIFE's Avatar
STB4LIFE
Just to add i did do plugs wires distrib. And then found my coil had a bunch of cracks in it prob due to the broken wires i found . So i have one ordered and it will be in tomorrow . I did replace all the injector seals and rtved the corners of the plenum. Oh and also top dead centered it at -5* and put the distributor on #1 . So it starts high rev. Then sputters and dies. But it was clearly misfiring and started popping like backfiring so some cylinders were lighting and some wernt intermittly .. thats why i checked the coil and i changed the oil out and it was gooey The oilfilter i drained it and the oil was super black from filtering soot. So i vacumed out all the oil with a lil copper tube and inspecting it wirh my bore camara... if this doesnt work off comes the pan again i guess then im doing the bearings also this time.
