a/c not working
Old May 9, 2025 | 10:37 AM
ruggles's Avatar
ruggles
Default a/c not working
Hi new to me 2003 Durango RT.. Just finished doing the plenum gasket job. What a dirty B of a job. Somehow one of the paper towels I used to block the ports while I was cleaning was still in there! Luckily I was able to fish it out with some chopsticks....
Anyways the a/c on this thing isn't working. The PO said it did last year and it does have a new compressor and was filled in April 2023, condenser replaced August 2023. Is it a leak? Blend door actuators?
Old May 9, 2025 | 11:10 AM
Need to put some gauges on it, and see what pressures are. If you didn't open the system during the course of your work, and it worked previously to said work, then it may be as simple as something didn't get plugged back in.
Old May 9, 2025 | 11:42 AM
ruggles's Avatar
ruggles
it hasn't worked for me. I just bought it a week ago. When I turn on the a/c the electric fan does come on. When I change the heat from hot to cold it doesn't change much in the cabin
Old May 9, 2025 | 12:00 PM
Does the compressor run??
Old May 9, 2025 | 12:04 PM
ruggles's Avatar
ruggles
I was wondering how to check that... I noticed that the rpms don't change when I turn it on so I was thinking it might not be turning on. Maybe a fuse or relay?
Old May 9, 2025 | 12:22 PM
Open the hood, start the engine, put it on max a/c, see if the compressor cycles..... If it doesn't, time to check pressures.
Old May 9, 2025 | 12:30 PM
ruggles's Avatar
ruggles
ok sounds like I have a leak in the system if it's gone less than 2 years since being filled
Old May 9, 2025 | 12:37 PM
Could all well be. Finding it is the fun part.
On my truck, after spending 600 bucks or more, my a/c still only works for a couple days..... Evap core is leaking.....
Old May 9, 2025 | 01:00 PM
ruggles's Avatar
ruggles
I have a buddy with a shop that can pressure test it for me. I'll probably do that
Old May 9, 2025 | 01:02 PM
It's good to have friends.
