Need helps in rebuild after caught fire...
Old Sep 8, 2025 | 12:17 PM
ChRiS_27's Avatar
ChRiS_27
Default Need helps in rebuild after caught fire...
Hi guys. It's a sad situation. My 99 5.2 Durango caught fire when I was driving. I love this car and have a huge fondness for it, so I decided to rebuild it. Therefore, I need your help. Please tell me where the wiring harness from the pics goes. It's the wiring harness of the air conditioning/vents control panel. I also need photos of the entire EVAP system, all the wires and related components. I also need a wiring diagram for the 46RE transmission, as it also burned a bit. Where can I buy a selector cable for this gearbox? I need to know where everything is in all the things I mentioned so I know how to rebuild it. Im from Poland and in Europe this car is very, very rare so i need your help guys..
Much respect form Poland!
PHOTOS: https://drive.google.com/file/d/1-hR...usp=drive_link
https://drive.google.com/file/d/1IyI...usp=drive_link
Old Sep 8, 2025 | 12:22 PM
No access to your pics. Need to set them as publicly viewable, or host them elsewhere.
Old Sep 8, 2025 | 12:37 PM
ChRiS_27's Avatar
ChRiS_27
Already done, sorry!
Old Sep 8, 2025 | 06:13 PM
How bad did it burn?? That's the vacuum harness for the HVAC box. The lines run out to all the actuators for the various doors..... May have to pull the dash to fix that.....
Old Sep 9, 2025 | 04:30 AM
ChRiS_27's Avatar
ChRiS_27
I will replace whole dashboard, for sure. Just before the fire, I noticed a very intense smell of gasoline and then so much smoke. So i jump of the car, pop the hood and flash by water. So I'll be replacing and inspecting every single part of the fuel and EVAP systems. The fire occurred exclusively at the rear of the engine and was quickly doused with water. The flames quickly disappeared. Later, only the interior plastic from the air vent tunnel was melting with smoke. Straight behind the radio but fun facts is probably all of the harness are good because there is no harness there I think? I managed to extinguish the EVAP lines by fire extinguisher about half a meter before the fuel tank...
Old Sep 9, 2025 | 06:22 AM
Moparite's Avatar
Moparite
You are lucky, Most fires don't get put out in time. I would see if you can find the source of the fire. The harness in the engine compartment may have been hit by it also. A service/parts manual will be a helpful if you are not familiar with the things you mentioned above.
Old Sep 9, 2025 | 06:47 AM
ChRiS_27's Avatar
ChRiS_27
Where I can get those? Maybe u know. I will check engine harness at rear engine too for sure and will try buy or repair.. But it's huge problem in Poland, this car is very, very rare here..
Old Sep 9, 2025 | 05:20 PM
Rebelwoc's Avatar
Rebelwoc
Default Service Manual
Chris, I have a 99 Durango and I bought this factory Service Manual. It's the real deal at this link https://ebay.us/m/rEDA8v
Dave
Old Sep 10, 2025 | 05:32 AM
ChRiS_27's Avatar
ChRiS_27
Thank u
