"01 durango problems?
Old Jan 13, 2006 | 07:12 PM
RangoRider's Avatar
RangoRider
Default "01 durango problems?
i am looking at buying a '01 durango slt plus with the 5.9 motor. it is a one owner that has been well maintained except... he never changed the tranmission fluid. when i fly in to look at his truck are there any items that should be looked at closely. also has anyone had any luck increasing the mpg of this motor? K&N? Mobil 1? etc. hope to make the flight next week sometime so your response will be appreciated.
Old Jan 15, 2006 | 12:51 PM
hydrashocker's Avatar
hydrashocker
Default RE: "01 durango problems?
Make sure he had the recall done on the ball joints. If not you can have them done. If you want gas mileage better buy a car. This is a bad a$$ truck. I get 11.5-13 MPG's in city and 15-17.4 on the hi way. That's good enough for me.[sm=gears.gif] Have that trans fluid and filter done!
Old May 31, 2015 | 11:30 PM
manoffaith521's Avatar
manoffaith521
I have a 2000 Dodge Durango 4.7 L. The voltage when starting goes up and then back down. The alternator was tested "Good" and I replaced the PCM, due to a bad voltage regulator. The PCM was flashed before installing. Can anyone help?
Old Jun 1, 2015 | 11:54 AM
Please stop posting the same question over and over in threads that are 10, 15 and 20 years old. Refer to your original thread here:
https://dodgeforum.com/forum/1st-gen...7481-help.html
