which brake rotors to get
Old Feb 9, 2006 | 07:54 PM
glordel's Avatar
glordel
Default which brake rotors to get
I tried to search for the subject but I am still confused on which front brake rotors to get for a 2000 durango should i stay with stock or got the ones with holes and grooves mine are warped now and I am going to replace them
Old Feb 10, 2006 | 12:30 AM
alanmac's Avatar
alanmac
Default RE: which brake rotors to get
Depends on what you want really, and how much money you are willing to spend. The difference in the rotors are simple. The slotted and drilled rotors dissipate heat, the solid stock ones don't. Which in turn wears down your brakes faster.
Old Feb 10, 2006 | 05:18 PM
Kensai's Avatar
Kensai
I also like to know if you change the rotors, can you upgrade to a bigger rotor without having to change anything else? I feel the Durangos have alot of fade on the front and the ABS keeps kicking in on teh back when you have to apply the brakes pretty hard. I was never able to get the front brakes to really grab to stop the vehicle. I thought maybe changing out to slotted or drilled bigger rotors with matching performance brake pads may provide better stopping power. I am hitting 69k miles on my 2000 R/T and still using OEM rotors like to upgrade to bigger better rotors when the time comes to change out the rotors.
Old Feb 12, 2006 | 03:24 AM
1 bad durango's Avatar
1 bad durango
if you go crossdrilled or slotted with good pads it will help but you should also upgrade to stainless brake line ,,,no you cannot just add bigger rotor without a kit
Old Feb 12, 2006 | 09:42 PM
hydrashocker's Avatar
hydrashocker
ORIGINAL: 1 bad durango
I agree with you on the bigger rotors. But please explain why do you would have to upgrade to a stainless brake line for the better pads and rotors. It is for looks and better abrasion properties. But it dose nothing for street performance. It you go off road a lot than yes, or lift your truck yes.
Going with Cross Drilled rotors and good pads will help stopping distance and help against warpage.
Old Feb 13, 2006 | 02:09 PM
kevman's Avatar
kevman
you need to put on stainless brake lines because the factory ones will expand when you hit the brakes and you lose stoping power going to the brakes
Old Mar 5, 2006 | 05:29 AM
Amaloney's Avatar
Amaloney
I agree, one of the major benefits of steel lines are that they do not expand. This makes your brakes react quicker and all the pressure goes into the pads not the lines. I work on races cars and that is exactly why steel lines are used.
