removing the head unit
Old Feb 16, 2006 | 04:25 PM
Durango4X4's Avatar
Durango4X4
Default removing the head unit
Can anyone tell me how to get the stock head unit out of a 2002 Durango? I dont want to just start pulling on stuff and beak and of the plastic. Thanks
Old Feb 16, 2006 | 09:56 PM
20durango00's Avatar
20durango00
Default RE: removing the head unit
It has been several years since I replaced ours on a 2000 Durango, thinking you have to take off the lower panel under the steering wheel first to gain access to the panel surrounding the radio, then you'll see how to go from there.
Old Feb 16, 2006 | 10:21 PM
Durango_24's Avatar
Durango_24
Its not going to be fun, but on my 03 I had to remove the screws at the top of the surround by the gauges, and then at the bottom of the dash (I think 2 on the drivers side and one towards the passenger side just before the glove box). The whole plastic from the gauges to the raido is all one piece. I pulled it out far enough to get the old radio out and the new one in. It did not pull off easy for me, but I did not break anything.
Old Feb 19, 2006 | 03:08 AM
Last Of The R/Ts's Avatar
Last Of The R/Ts
Taking the dash out is not hard at all, just make sure you have all the screws out before you go yanking.
Old Mar 7, 2006 | 03:51 AM
dannyac's Avatar
dannyac
Unscrew the panel below the steering wheel, then just grab the plastic trim and gently pull. It'll pop off with no worries. From there, there are a few screws holding the headunit in.
