fuse blowing my mind
Old Mar 4, 2006 | 03:45 PM
20durango00's Avatar
20durango00
Default fuse blowing my mind
Did it again, the 20A fuse for the horn/ac comp. keeps blowing. I have isolated the horns and installed a new relay, still blows. Wife said it blew this morning when she turned on the heat/defrost, so, could it be the heat-air-defrost **** switch??? This is a 30,000mi. 2000 Durango, we bought new. What are the weak points in such a low mile vehicle such as this??? Thanks, guys.
Old Mar 4, 2006 | 10:21 PM
20durango00
Default RE: fuse blowing my mind
I FINALLY FIXED IT !!!!! Always check the simple things first, right. Well I never thought to look at the battery, but the positive terminal was highly corroded (short culprit) under the red rubber cover and the negative terminal was on its way. I cleaned both terminals, installed new fuse, ran the a/c, heat, defrost & blew the horn at the same time over and over. Spring is around the corner and the wife was beginning to get concerned about the a/c, alls well now. A BIG THANKS to hydrashocker and chump for the informative feedback.
Old Mar 12, 2006 | 12:30 AM
MikeNAmyS's Avatar
MikeNAmyS
Did the neighbors call the cops or the guys in the white coats?
Glad to hear it was an easy fix and that you found it!
Old Mar 26, 2006 | 11:23 PM
hydrashocker's Avatar
hydrashocker
Thanks for the feed back. I've seen some strange things happen with battery connections and dead cells. I'll have to put this one in my book tho.
Old Mar 28, 2006 | 11:36 AM
Kensai's Avatar
Kensai
Same here, never thought a corroded battery terminal would blow fuses? maybe it is because the alternator is sending spike voltages or power in trying to charge the battery thinking it is nearly depleted?
I have a 2000 D also but I have installed those anti-corrosive pads on my battery posts and even sprayed some anti-corrosive coating on the posts so they still look new today. Luckily I did or I may have experienced something similar to what you experienced.
Old Mar 29, 2006 | 02:50 AM
henry75's Avatar
henry75
i lost the battery in my D last week. gave no notice just BAM would not start. new battery fixed it right up. never had one die like that. as for the corrosion i ahev all gold connectors to the battery. seems to never corrode so i recommend going that way. just be careful not to over tighten.
Old Apr 9, 2006 | 06:08 AM
titan2087's Avatar
titan2087
possibly when the ac kicked in the high amp loud it takes to start up and the very littel jucie it was getting from the corroded battery may have had sometihng to do with the fuse blowing goodness.
Old Apr 9, 2006 | 09:14 PM
hydrashocker
ORIGINAL: titan2087
I think what he is trying to say is:
The AMP load on start up for the A/C comes from the battery, therefor blowing the fuse because of resistance due to bad connections.
Old Apr 9, 2006 | 11:37 PM
titan2087's Avatar
titan2087
Yes sir E he hit it right on the money just better worded.
