reverse lights and wiring diagram
Old Mar 13, 2006 | 03:12 PM
blondy's Avatar
blondy
Default reverse lights and wiring diagram
Hey,
This is my first post, but having a problem. My reverse lights won't work. Have replaced the lights and the fuse. The fuse blows as soon as you turn the engine on, before you even turn the lights on. hoping to find a wiring diagram to be able to trace the wire, but would appreciate any good ideas.
Thanks
Old May 27, 2012 | 11:29 PM
jthayer5's Avatar
jthayer5
Default Same problem
I see this is an old post, but I am currently having the same problem with my 2000 Dodge Durango. Any help is appreciated.
Old May 28, 2012 | 12:13 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Are you also blowing the fuse too. If not, What is the engine size. This way we know what type of transmission you have.
Old May 28, 2012 | 02:01 PM
Old_School's Avatar
Old_School
Check your neutral safety switch and the harness that it connects to it ... i have seem several 98-00 (mine included) that the harness melts over time from the heat produced from the transmission. There are 3 wires going into it... center one is the gear sense wire and the 2 outers wires are for the reverse lights... its possible the wires could have melted together and causing the fuse to blow....
Old May 28, 2012 | 02:59 PM
jmess's Avatar
jmess
i had this exact issue as well. sadly i couldnt find a harness at the time. so i busted out the sautering iron and sautered the wires directly to the connectors. havnt had an issue since
Old May 28, 2012 | 03:11 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sautering? what is that? lol
think you meant soldering
Old May 28, 2012 | 03:29 PM
jmess's Avatar
jmess
yea sorry. i grew up with my step father who liked to call things whatever he wanted and thats what i always heard it referred to as until i learned how to do it myself. still call it the wrong name though lol
Old May 28, 2012 | 03:45 PM
jthayer5's Avatar
jthayer5
@master tech: Thanks for the welcome. Yes, the fuse is blowing as soon as I turn the key. It is the 5.9L engine if that helps.
@Old_School: I will try to find that. In case I don't get to it before I come back here, where is it located on the transmission?
Thanks to all for replying so quickly.
Old May 28, 2012 | 04:18 PM
Old_School's Avatar
Old_School
On mine it was located on the left side close to the front.. yours being a 2000 there where more than one trans used.. let us know what motor you have and we can ID the trans and tell you alittle better where it is
Old May 28, 2012 | 11:12 PM
master tech
If you blowing the fuse, Then you have a short in the circuit. Have you had any work done to the truck?
