PCM Question
Old Apr 18, 2006 | 11:29 PM
feirsquickfire's Avatar
feirsquickfire
Default PCM Question
Got a good one. My truck won't start. When I leave it in the on position, my oddometer starts to flash, then after a few seconds the words "no bus" appear where the oddometer is. Also, when I get that no bus code, my check engine light, low fuel light, ABS light and my break light all come on. The starter is engaging, but the engine won't turn over. Does anyone have any idea as to what, other than the PCM could be wrong? Thanks in addvance.
Old Apr 20, 2006 | 02:52 AM
hydrashocker's Avatar
hydrashocker
Default RE: PCM Question
Maybe a bad battery cell or loose connection.
Old Apr 20, 2006 | 10:21 PM
feirsquickfire
Tried that, the battery is good and I change the terminals out a few months ago. Had some one tell me it might be the speed sensor.
Old Apr 25, 2006 | 01:37 AM
1 bad durango's Avatar
1 bad durango
my friends d did that too it was water in the connections ,you have three plugs that go to you pcm make sure each of those are dry from any moisture
