Speedometer doesnt work until I hit 40 MPH
Old Jun 1, 2006 | 04:53 PM
LLCPREZ's Avatar
LLCPREZ
Default Speedometer doesnt work until I hit 40 MPH
Hi everyone,
I'm just wondering why my 1999 Durango's speedometer doesnt work until I hit 40MPH.
Until I hit 40MPH, it just stays down at 0MPH.
Has anyone experienced this, and also do you know how to fix it?
Thanks,
LW
Old Jun 1, 2006 | 07:14 PM
slightlya's Avatar
slightlya
Default RE: Speedometer doesnt work until I hit 40 MPH
Two possibilities I can think of. First, have you had any transmission work done? Second, have you also had problems with the brake lights coming on (the BRAKE and ABS lights)? Both of these can affect the speedometer, although with the transmission it usually just makes it not work at all. The ABS sensor is probably the most likely candidate. It could just be a bad speedometer cable, but again, I wouldn't expect it to start working at 40mph, rather I'd expect it to not work at all, or work incorrectly (read 25mph when you're passing cars on the freeway).
Old Jun 1, 2006 | 07:19 PM
LLCPREZ's Avatar
LLCPREZ
Yes,
My ABS sensor is bad on one of my front tires. Not sure which one. The part is cheap, so I will try to have my mechanic look at it.
Old Jun 1, 2006 | 10:51 PM
yakkier's Avatar
yakkier
if that doesnt fix it, IS your check engine light on ? if so then replace your speed sensor, it's located ontop of your rear axle, in the top center of the pumpkin, they'er 40 bucks at the dealers, mine went out not to long ago so yea.. been there done that
Old Jul 1, 2006 | 04:41 AM
IndyDurango's Avatar
IndyDurango
Your problem is the rear axle speed sensor. It'll take you about 10 minutes to change and 5 of that'll be getting under there to do it. Part cost about $29
One bolt, one plug… 10 minutes. Saves big on going to the dealer.
IndyDurango
Old Jul 4, 2006 | 04:19 PM
spectre184's Avatar
spectre184
Yep i agree with Indydurango (BTW I live in Terre Haute ). My brothers D did same thing. Here is reply I did about same problem. My reply id 1/2 way down.
