Ginding Sound When Turning The Wheel
Old Jun 18, 2006 | 06:02 PM
jtuione's Avatar
jtuione
Default Ginding Sound When Turning The Wheel
Hi there,
I recently purchased a 2002 Dodge Durango and am now hearing a grinding sound when I turn the wheel almost all the way to the right. It is extremely noticable when I am in reverse and turning the wheel. I've read other posts where the hear a ginding noise when in reverse. However, when in reverse I fine, its only when I start turning the wheel to the right. I do not hear the sound when I turn to the left. Any ideas? Is it serious? Any help would be appreciated. Thanks.
Old Jun 20, 2006 | 03:38 AM
Digitoxin's Avatar
Digitoxin
Default RE: Ginding Sound When Turning The Wheel
ORIGINAL: jtuione
Hi there,
Do you have stock tire size?
Old Jun 24, 2006 | 05:21 PM
jtuione's Avatar
jtuione
Yes, I have stock tires and rims. If I were to turn the wheel all the way to the right and then put it in reverse, it makes a heavy grinding sound. I just can seem to figure it out.
Old Jun 25, 2006 | 03:58 AM
RebelX's Avatar
RebelX
i have the same problem. except my wheels can be straight. but when i back up it groans n grinds..starting to do it in forwards now....gotta get to the shop n have it checked out....just need a replacement daily driver to do it.
Old Jun 27, 2006 | 04:31 AM
jtuione's Avatar
jtuione
Let me know what they say when u get a chance. I just wondering if it is major, meaning is my front end going to fall apart? Anything would be helpful.
Old Jun 27, 2006 | 06:40 AM
RebelX's Avatar
RebelX
i did some checking tonite and found out that my upper balljoints are worn horribly. they move about 3/8" so its being dropped off at the shop tommorrow to get fixed plus im having the shop check out my wheel bearings also.
Old Jun 27, 2006 | 04:23 PM
jtuione's Avatar
jtuione
How much did they quote you for everything together?
Old Jun 27, 2006 | 07:25 PM
yakkier's Avatar
yakkier
Ball joints are a big pain in the ***, before you have them do it goto the dealership there was a recall on the upperball joins an rearbrakelines for the 00-02 models, if it was not done during the recall the dealer will do it for free
Old Jun 27, 2006 | 09:21 PM
jtuione's Avatar
jtuione
Thanks for the information, I'll definately look into it.
Old Jun 28, 2006 | 06:07 AM
RebelX's Avatar
RebelX
ill do the same. just gotta call em n have em run the vin. jtuione....not sure what actually costs to have em done. im just paying for parts n go in after hours n he helps me do them myself...good friend to have is someone who owns their own shop n lets you use their stuff when you ask em.
but to make a guess..id say around 300-500 to replace the balljoints depending on how much trouble they have removing the old ones.
