Upper control arm bushings
Old Jun 22, 2006 | 01:13 AM
Remmy's Avatar
Remmy
Default Upper control arm bushings
Hopefully someone can help, I have a 02 Durango 2wd and I need to replace the two upper control arm bushings, what I am trying to find out is whether there machine pressed in & out. I called three different stealerships and one said yes they need to be machine pressed, the other said no & the other said, "not a clue". The stealership wanted to charge me $960.00 to do it and front shocks(not including an alignment). I figured I might be able to do it cheaper. Does anyone know?
Thanks
Old Jun 22, 2006 | 02:18 AM
yakkier's Avatar
yakkier
Default RE: Upper control arm bushings
big *** hammer an a crowbar..
Old Jun 22, 2006 | 12:54 PM
hydrashocker's Avatar
hydrashocker
[sm=funnypostabove.gif]
You can get a tie rod separator, stick it in between them and smack it with a mallet. They will separate. Look on E-bay because you can usually fine the replacement parts for cheap. You should replace the whole thing not just the bushings.
