01 durango stalling
Old Jul 27, 2006 | 01:06 PM
jad866's Avatar
jad866
Default 01 durango stalling
I HAVE A 01 DURANGO THAT KEEPS STALLING AT VERY LOW RPM'S. LIKE WHEN YOU ARE JUST ABOUT STOPPED AT A STOP SIGN OR BACKING INTO A PARKING SPOT. I HAVE ALREADY CLEANED THE THROTTLE BODY AND PURCHASED A NEW IAC SOLENOID. I AM NOT GETTING A LIGHT ON THE DASH IVE HAD A VOLT METER ON THE TPS AND IT SEEMS TO BE GETTING THE PROPER VOLTAGE UP AND DOWN THE RPM RANGE I AM AT A LOSS PLEASE HELP.
Old Jul 28, 2006 | 04:16 AM
IndyDurango's Avatar
IndyDurango
Default RE: 01 durango stalling
TPS
Throttle Position Sensor, about $30 aftermarket.
IndyDurango
Old Aug 27, 2007 | 01:14 PM
DurangoRT/RN's Avatar
DurangoRT/RN
This is an old post Indy, but can it be the Throttle Position Sensor even if you have NO codes? Mine just says done... No numbers?? But I am having this same problem.
If anyone else knows Please let me know. I'm trying to get this fixed today.
Thanks!
Old Aug 27, 2007 | 01:29 PM
Kensai's Avatar
Kensai
You can have a malfunctioning throttle position sensor and it will not throw a code. This has happen to me. My engine will surge periodically especially with cruise control set. I fought with the dealer for almost 2 months and they still cannot find the problem but they cannot feel the power surge either when they test drive it. So I just went out and replaced the TPS based from the users in this forum's recommendations. I no longer have any surging or idling issues.
Old Aug 28, 2007 | 11:38 PM
IndyDurango
Kensai is correct. You can have issues and no code.
IndyD
Old Aug 29, 2007 | 02:48 AM
DurangoRT/RN
Thanks Kensai & Indy... Turned out to be only the pesky battery not connecting right [:@].
I love you guys. Men I can depend on... The thousands of $s I've saved from this forum!!
He's running like a dream again. I love my truck!
Going to take him to South Padre Island this weekend and let him free on the dunes.
I literally tore him up3 yrs agodoing this and he's still a trooper .
It was one of the funnest nights of my life !
Any tips on how to not overheat your truck on the beach?
Old Aug 29, 2007 | 04:25 AM
Mean Green's Avatar
Mean Green
Don't run the a/c??? I would suggest if you have an overheating issue when wheeling change your t-stat, if the problem persists then look into a HD fan clutch.
Old Aug 29, 2007 | 08:56 AM
Kensai's Avatar
Kensai
Other than that, don't get alot of sand thrown into the radiator! haha, can't be helped I guess if you play too hard!
You may want to lower the psi on the tires so it will have more traction in the sand and will help your engine from working too hard. High PSI's makes your regular tires too hard and they will act like knifes and will just slice into the sand and cause your D to sink into it and then your engine will work overtime to push the D thru the sand. I usually lower my tires down to 10 psi. Of course, you better have a portable air pump to pump up your tires to normal psi before you leave the beach.
