Durango Blower Switch
Old Sep 15, 2007 | 09:17 PM
  #31
jej3's Avatar
jej3
Default RE: Durango Blower Switch
Just wanted to say thanks to this forum. We had the exact same issue on my wife's Durango this afternoon. She called me mad as could be, I googled this forum, bought the part from the dealer (yes on a Saturday) and fixed it in less than 2 hours. Total replacement time was 20 minutes. I could do the next one, which I imagine will happen, in 5 minutes.
Thanks everyone. I'll be reading this forum from now on!
Old Sep 15, 2007 | 09:20 PM
  #32
Mean Green's Avatar
Mean Green
Glad to be of assistance!
Old Jan 2, 2008 | 10:07 PM
  #33
appraiserguy's Avatar
appraiserguy
Anybody helped Worldpeace? It seems that my fan is also blowing mostly out the dash, very little to the floor or windshield. Its like it is not shutting a damper or something. Any ideas?
Old Jan 19, 2008 | 07:05 PM
  #34
DurangoShark's Avatar
DurangoShark
Just had same problem. Blower motor worked fine for 4 hour trip on Thursday, and 4 hours back on Friday. Saturday morning - the blower only blows air on high setting.First I checked out all thefuses, and nothing blown. Then Ifound this forum.Itook out the blower motor resistor component as described earlier. Went to Dodge parts - got part number 1-05061575AA (for 2003 Durango). Put it in, and blower works like new. Guy in parts window said it is a very common problem - and said "hey you got 5 years out of the old one" like that was something I should be happy about. Part was $22.00 list price plus tax. (This part looks much different thanwhat I took out - so they definately have re-engineered it). Mopar part had amanufacture dateon box of09-26-07, andmade in Slovenia. Thank you so much for your help and expert advice. You guys areG R E A T!!!
Old Jan 22, 2008 | 09:56 AM
  #35
DerfW3's Avatar
DerfW3
Thanks for keeping it here 'cause I have the same problem as well. Fantastic info! Now if I could just get the rear heater going.
Old Feb 19, 2008 | 09:58 AM
  #36
mpen's Avatar
mpen
I have a 2003 durango, I thought the blower resistor was the problem so I changed it. Heater worked good for awhile, then It would quit workign at times. If you wiggle the wires going into the blower resistor it would usally start working again. The other day I could smell wires melting & the heater quit. I inspected the blow resistor plug & could see where 1 wire had been hot & melted some of the insulation. I think the plug was not making good connection in the socket. But it has melted the socket to the blower resistor &I think I will have to replace the socket (don't know if this is availible from dealer) & the blower resistor. Could a loose socket be the reason the wire melted? I think it was a blue/ brown stripe wire that melted, I think it controls high on the fan motor.
Old Feb 20, 2008 | 07:24 PM
  #37
Kensai's Avatar
Kensai
The wiring harness was mentioned in part of the repair on this thread that it may be the main issue of causing the blower resistor to go out more than once. So in your case, you may need to replace the wiring harness if the dealer does not have a replacement socket. I think the wiring harness will come with a new socket.
Also, inspect the harness and the surrounding areas where the harness resides. Make sure there is no moisture or anything that may be causing the harness to fail.
Old Feb 20, 2008 | 08:36 PM
  #38
MAGIC84's Avatar
MAGIC84
2 hours, should have taken about 20 minutes. Be honest with us how many bars did you visit in the mean time? you are among friends. LOL!!!!
Old Apr 27, 2008 | 10:00 PM
  #39
daisydurnago51's Avatar
daisydurnago51
To all the folks with the blower resistor advice--THANK YOU!!!! I was becoming the "irritated wife" when I happened on "The Dodge Forum" and found the answer to our exact same problem--the blower only worked on high and our mechanic said he thought it could be as much as $500.00! That wasn't going over well with the hubby so I was very glad to get the part, follow the photos, and have it fixed 20 minutes and $19.00 later. (I had to get a universal lug wrench attachment so the extra $4.00!) I will look forward to checking the forum out for future mechanical problems--they will come!
Old Apr 28, 2008 | 04:16 PM
  #40
Overcast72's Avatar
Overcast72
ORIGINAL: daisydurnago51
To all the folks with the blower resistor advice--THANK YOU!!!! I was becoming the "irritated wife" when I happened on "The Dodge Forum" and found the answer to our exact same problem--the blower only worked on high and our mechanic said he thought it could be as much as $500.00! ...
How sadly typical
Although - you know... keep an old one around - and use it to 'test the mechanic'
