Durango Blower Switch
Old Jan 2, 2011 | 06:41 PM
  #131
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
that sounds to me like something is wrong with or jammed in the switch, iw ould pull the switch out and look for any broken parts
Old Jan 2, 2011 | 09:34 PM
  #132
samelewis's Avatar
samelewis
I might go the junk yard, and check for a switch, just in case. Not too crazy about paying $105 for a new one. Guess I'll try the switch first, then check the resistor and blower motor after that.
Thanks for the replys.
Old Jan 3, 2011 | 01:03 PM
  #133
samelewis's Avatar
samelewis
Well, the switch was bad. I was able to get another one from the junk yard for $8. Well worth the trip.
Old Jan 3, 2011 | 04:36 PM
  #134
shrpshtr325
THE ULTI-MOD
thanks for letting us know how it went and glad that you got it fixed nice and cheaply
Old Jan 3, 2011 | 10:24 PM
  #135
IndyDurango's Avatar
IndyDurango
Not going back to the beginning of this thread to check... but an $8 solution for a 14 page thread? WTF?!
IndyD
Old Jan 3, 2011 | 10:26 PM
  #136
shrpshtr325
THE ULTI-MOD
indy, he didnt start a new thread, it started in 06 and just keeps coming back, and i was too lazy to split it off
Old Mar 15, 2011 | 05:08 PM
  #137
arcticpower28's Avatar
arcticpower28
I looking for a resistor wireing kit along with a new resistor. Does anyone have any part numbers for these two things. I did read somewhere that there is a better built resistor I would like to have that part number, along with the heavy duty wire harness, Thanks
Old Mar 15, 2011 | 07:31 PM
  #138
MAGIC84's Avatar
MAGIC84
To be honest I would go to salvage yard for wiring harness. Shouldnt be more than about $20. Dealer resistors run about $15 you can find them on eBay for about the same but when you add shipping it comes out more. If you get the salvage yard harness just follow the wire. Cut as far up against the fire wall as possible that way you have extra wire. Inspect wire harness closely to make sure you dont have the same damage you are trying to repair. Also you maybe able to find Dakota as donor...the wiring harness is the same but verify. After that it is a matter of matching and splicing the wires.
Old Apr 21, 2011 | 12:16 PM
  #139
mzygmunt's Avatar
mzygmunt
Got kind of a different issue, got a 99 and what's going on is all my speeds work, however, what I'm having problems with is no matter which setting I have it on, the air comes out of the defroster vents and not the dash... rear works fine, it's just the front... any ideas?? It's startin to get too hot here in AZ to not have the AC blowin.
Old Apr 21, 2011 | 06:48 PM
  #140
IndyDurango
mzy,
Different issue = Start a new thread. Always.
Answer = blend door.
