TIRES RUBBING
Old Aug 31, 2006 | 03:32 PM
ONEENVY's Avatar
ONEENVY
Default TIRES RUBBING
My front tires rub when I do hard turns. I have a 2in body lift. The tires are 33in 12.5w widcat a/t. Half the plastic wheel well has already been cut off to stop it from rubbing. Should I just take them off? The driver side is cut 2-3in higher than the passenger side is and the passenger side is doing most the rubbing. Maybe I should even the passenger sideout? Would a suspension lift help stop the rubbing?
Old Aug 31, 2006 | 04:00 PM
ONEENVY's Avatar
ONEENVY
Default RE: TIRES RUBBING
Oh also I dont think they resent my speedo when they did the lift and bigger tires (I think this cause i was doing 60mph and passsing everyone, gave a call to my friend driving behind me and he said I was doing 70mph. He paced me and I was about 8mph faster than what the speedo read). Is this something I can do or should les schwab or someplace like that do it?
Old Aug 31, 2006 | 05:44 PM
Kensai's Avatar
Kensai
You will have to take it to a specialty shop that can reprogram the PCM to compensate for your tires. Or you can buy yourself a hypertech programmer and it can calibrate your speedo as well as retune your PCM for more power.
http://www.hypertech.com
Just went to visit that site and seems that Hypertech has rebuilt their programmer now called Hyperpac! Now with touchscreen controls and tons of new features. Pretty cool and I bet it is pretty expensive. At least much more expensive than their previous Hypertech III programmer.
I would love to have one of those.
Old Aug 31, 2006 | 05:48 PM
Kensai's Avatar
Kensai
You may want to change out the rims for a set of rims that can position your tires outward a little more so it won't rub the inside fender well?
Old Aug 31, 2006 | 07:48 PM
JasonGS's Avatar
JasonGS
1st issue: for the rubbing tires, most don't go with that size of a tire without a bigger lift than just the T/S. You will have to trim the wheel well liner, and possibly the front bumper. Also, the tires being that wide are probably also rubbing the frame. Like Kensai said, an easy solution is to get wheels with a smaller backspacing.
2nd issue: depends on what engine you have. If you have a 4.7, then you cannot get the Hypertech. However, you can get a SuperChips programmer to change the tire size in your computer. That will fix the speedo.
Old Sep 3, 2006 | 02:33 PM
hydrashocker's Avatar
hydrashocker
ORIGINAL: JasonGS
Agreed
