DAYTIME RUNNING LIGHTS
Old Sep 11, 2006 | 12:14 PM
stephano's Avatar
stephano
Default DAYTIME RUNNING LIGHTS
HI GANG
I m from canada and my 2000 R/T is equipped with oem daytime running light. The problem is that even if my key is off, the high beams stays on. The only way to turn them off isto disconnect the DRL module..... I dont really need it but my high beam indicator doesnt work anymore....anyone can help ? I dont wanna spend 130 $ for a new drl module,
steph
Old Sep 12, 2006 | 12:25 AM
Mean Green's Avatar
Mean Green
Default RE: DAYTIME RUNNING LIGHTS
Maybe it is the multi-function lever.
Old Sep 14, 2006 | 10:00 PM
hydrashocker's Avatar
hydrashocker
First off Welcome.
Your problem might be in your switch. Check it first.
Old Sep 15, 2006 | 12:37 PM
Kensai's Avatar
Kensai
Interesting to see a Durango with daytime running lights. I first thought they would use the lower driving lights as daytime running lights instead of the main headlights.
Old Sep 15, 2006 | 02:19 PM
stephano's Avatar
stephano
They work with the high beams at 50% power , thats why the drl module for .
stephano
Old Sep 16, 2006 | 04:39 AM
hydrashocker
I've never seen a Durango with day time running lamps. Sounds like an after market system. I would ask a dealer (give them the VIN#) if it was on the truck when it was sold because I don't think so.
Old Sep 16, 2006 | 05:48 AM
IndyDurango's Avatar
IndyDurango
While I don't know what the problem is (switch?), I can confirm the D has DTRs in Canada. Canadian law has required them for a few years. In the US, they are still an option. Personally, they take away from one of the advantages a motorcycle had, a headlight on during the day. The more there are DTRs the less likely one is to notice. Thus, lessons the effectiveness overall. DTRs = diminishing returns.
IndyD
Old Sep 16, 2006 | 11:45 PM
hydrashocker
Being a rider I know of that. It sucks. I didn't know that Canada has them standered. Can you get one to hook up to our rides (OEM)?
