Cigarette Lighter Socket
Old Aug 19, 2009 | 11:03 AM
scientist's Avatar
scientist
I attached the wiring diagram for the cigarette lighter and the aux power.
File Type: pdf
Old Aug 22, 2009 | 01:22 AM
hydrashocker's Avatar
hydrashocker
There is a 15 amp fuse in the fuse panel in the dash drivers side.
Old Jan 19, 2010 | 07:55 PM
maxrich's Avatar
maxrich
Default I have the same problem -- Help?
Hey guys, did y'all figure this out? I blew both the cigarette lighter and the 12v "power outlet" using a heater that was supposedly designed for car use, but I guess not. I found the fuse to the left of the drivers seat for the cigarette lighter, but it didn't affect the (non) working of the 12v constant on power outlet. BTW, mine's a 1998, the first year. Please email me at madmaxrich@gmail.com if you have any leads, suggestions, or an outright fix.
Max
Birmingham, AL
Old Jan 20, 2010 | 12:30 AM
hydrashocker
There is a 15 amp fuse in the fuse panel in the dash drivers side. It might be behind the one you can see in the dash opening inside the cap(there are 4 fuses). It's a real bitch to get to tho. Not sure on the years that had it tho.
Old Jan 25, 2010 | 11:22 PM
zootzee's Avatar
zootzee
My 2cents.
The plug on the dash works and the heated seats work, but the plug in the consol doesn't work.
Old Jan 26, 2010 | 12:43 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by zootzee
My 2cents.
that doesnt help, but thanks for trying . . .
Old Jan 26, 2010 | 10:54 PM
hydrashocker
Cigarette lighters and AUX power supplies are on different fuses.
Old Jan 31, 2010 | 09:05 PM
BeachBoy's Avatar
BeachBoy
Yep, I had the same problem. The fuse for the Aux. plug is on the BACK SIDE of the fuse panel. To get to it, pretty much put your head on the brake pedal and look left. If you have girly hands like me, you should be able to reach it. I think there are four fuses there for some reason.
Old Jan 31, 2010 | 09:55 PM
hydrashocker
Who ever decided to install it in that location should be shot!.....LOL
Old Jan 31, 2010 | 11:23 PM
tm985's Avatar
tm985
The one that says Power outlet works on mine luckily enough I have one of them but the cigarette lighter on mine doesn't work either. I'd like to knwo if this is a doable fix if so I'll take care of it if not I can live with it I suppose.
