Cigarette Lighter Socket
Old 10-29-2010 | 02:15 AM
MikeyB1124's Avatar
MikeyB1124
Originally Posted by brossow
I found pictures elsewhere and my '01 R/T definitely does not have this "extra" panel of fuses. From something I read in yet another forum, it seems this changed for 2001+ models.
where did u find pic i like to see them so i at least know what im looking for
  #32
Old 10-29-2010 | 04:43 PM
hydrashocker's Avatar
hydrashocker
Here:
  #33
Old 10-29-2010 | 06:15 PM
MikeyB1124's Avatar
MikeyB1124
thank you for the picture
  #34
Old 11-28-2010 | 03:39 AM
02DurangoR/T_Milw's Avatar
02DurangoR/T_Milw
Hydrashocker, I looked at you pdf file and I have already found that fuse block but all of those are good. I just went out and looked again and I cant find that block.
Oh well I should have listened to everyone when they told me to stay away from Mopar. lol Thanks for trying to help.
  #35
Old 09-26-2011 | 02:58 PM
Dirtrango's Avatar
Dirtrango
Pulling up this old thread but i need to. My AUX outlets work but my Cig does not. I checked all the fuses and the cig is fine but now I'm concerned about the other 4 fuses on the left of the column under the dash. There are supposed to be 4 in there? I only have 2 in there if looking at it i have the 1st and 3rd counting from the dash tword the firewall. What are theses 4 fuses and do they all have to be there? and how the heck do i get my cig lighter working. lol
  #36
Old 09-26-2011 | 04:30 PM
srch4me's Avatar
srch4me
check the wiring connecting to the outlet
  #37
Old 09-26-2011 | 05:01 PM
adukart's Avatar
adukart
By checking did you look at the fuse or swap it? Fuses can look good and still be bad. If it isn't the fuse check for power at the fuse and go from there, like search was saying check for power at the connections.
  #38
Old 09-26-2011 | 10:26 PM
hydrashocker
Well the regular cigarette lighter fuse in the ash tray should be in the regular panel. It could be the lead going to it. Pull it and start testing.
Here are some pic's for the hidden fuss box that might help everyone. Taken from here: https://dodgeforum.com/forum/1st-gen...or-lights.html
Here is my '99's.. Has two fuses back there. I'm sure the '98's are similar to the 99-00. Your guess is as good as mine as to what they control.
My '01 had no fuses back there. Safe to assume they deleted this hidden fuse panel on the 01+ trucks.
  #39
Old 09-27-2011 | 04:16 PM
Dirtrango's Avatar
Dirtrango
OO Thanks. I might have found out what the problem is. I was under the dash (kinda hard to do with my back and neck issues) and have a wire with a weird looking fuse in it going from somewhere in the fuse panel then in the direction of the lighter. So have to trace it out and see what it is. maybe someone wired something up and tied into it. I hate when morons that don't know jack mess with stuff.
  #40
Old 12-23-2011 | 10:06 AM
jmcarmon's Avatar
jmcarmon
Same problem with my 2002 Dakota. I accidentally shorted it and it hasn't worked since. The dash lighter works fine but I need both. I tried to take the console apart but no dice. I did see the conductors feeding the power port socket and had voltage there. I am thinking it is a mechanical problem rather than an electrical problem but using small mirrors I cannot see any visible damage. ??? Shamrock
Quick Reply: Cigarette Lighter Socket
