Mobil 1 ATF okay for our transmission?
Old Jul 14, 2004 | 03:20 AM
slza805's Avatar
slza805
Default Mobil 1 ATF okay for our transmission?
Anyone use Mobil 1 ATF for our Durango transmissions or must I go to the stealership and get the Mopar approved ATF? I plan on changing out the transmission filter and fluids this weekend.
Thanks.
Old Jul 14, 2004 | 09:51 AM
rcs426's Avatar
rcs426
Default RE: Mobil 1 ATF okay for our transmission?
i wouldn't use m1 unless u change and flush all 12qts. out first
Old Jul 14, 2004 | 12:48 PM
slza805's Avatar
slza805
So the answer is YES it can be used but you must flush all 12qts??? Anyone else?
Old Jul 14, 2004 | 04:31 PM
JDELUNA's Avatar
JDELUNA
I believe that the Chrysler one is also synthetic too.
Old Jul 14, 2004 | 05:32 PM
slza805's Avatar
slza805
Does anyone here use Mobil 1 or other synthetics other than the Mopar products for their transmission?
I am assuming MOBIL 1 ATF is fine then but 12qts a guy at the part stores stated 4 qts only?
Old Jul 14, 2004 | 05:35 PM
jhnrckr's Avatar
jhnrckr
What is the recommend change interval for trans fluid anyway?
Old Jul 14, 2004 | 06:01 PM
rockadaous's Avatar
rockadaous
according to the book of all knowing
4qts for drain and refill
9-11 qts for dry fill (depending on model and options)
every 37,500 or 30 months for fluid and filter
Old Jul 14, 2004 | 06:25 PM
slza805's Avatar
slza805
ROCK,
So 4qts and replacement filter and I should be fine for a 2K Durango 5.2L 4x2?
Old Dec 30, 2004 | 04:52 AM
code3's Avatar
code3
I added Amsoil ATF to my 98 D and has had no problems.
Old Dec 30, 2004 | 05:02 AM
code3's Avatar
code3
Rock - I plan to change out my oil on a 98 D 4x4 slt 5.9L. How many quarts do I need to fill or replace the old oil??
