98 durango trans prob
Old Jul 26, 2004 | 12:25 AM
dango's Avatar
dango
Default 98 durango trans prob
need help...I have a 98 durango that has had overdrive replaced recently and today the check engine light came on and trans will not shift out of low.....any help
Old Jul 26, 2004 | 12:34 AM
rockadaous's Avatar
rockadaous
Default RE: 98 durango trans prob
welcome to the boards dango. sorry to hear about your troubles.
Old Jul 26, 2004 | 06:18 PM
robust57's Avatar
robust57
I am wondering if you are referring to 4Lo cause I don't know of any other low gear for the durango since the gearing is D-2-1 (atleast in my 98 durango). More info.
Old Jul 26, 2004 | 06:59 PM
slza805's Avatar
slza805
What code are you getting off the check engine light?
Old Jul 27, 2004 | 04:38 PM
slza805's Avatar
slza805
Just in case you are the one who emailed me about the how to get the codes, here you go.
Getting Computer Codes
Just cycle the key to the on position 3 times (don't turn the car on). In the readout where the odometer usually displays, your codes will each display for a matter of about 3 seconds each. When the last code has displayed, it will read "done". Pretty nifty. (espepcially if it doesn't have any codes to read)
Here is a link to some codes:
http://www.allpar.com/fix/2001-codes.pdf
*not sure if they are up to date or still the same but Im sure someone will post it.
Old Jul 28, 2004 | 12:44 AM
rcs426's Avatar
rcs426
i was under the impression that dodge did away with sefl test by cycling the key . my 98 d dosen't self test. correct me if im wrong. i use a scanner from snapon
Old Jul 28, 2004 | 02:19 AM
slza805's Avatar
slza805
RCS426,
I have a 2000 Durango and it still works. I also confirmed (double checked) the code I received with a clerk from Autozone with their tester to make sure its the same digits. They guys I deal with at AutoZone that I deal with here in SA, TX, alway seem to know the right parts for our Durango. Sad thing they have also projected what else might go wrong with it the near future. Like right now I gave them some symptoms of my front end and they say they can order some new upper ball joints. Oh well....
Old Jul 28, 2004 | 02:21 AM
slza805's Avatar
slza805
excuse my grammar... 8 beers and still going at the moment. Plus I cant edit my last post for some reason.[8D]
Old Aug 2, 2004 | 06:02 PM
Kensai's Avatar
Kensai
ORIGINAL: dango
My 2000 Durango did the similar thing. Check engine light came on and transmission was stuck in 1st or 2nd gear. Fortunately my Durango was still under warranty. I'll pull up the paperwork to see what was done. I think it was a governor and one sensor. I will update ya when i get the paperwork pulled out.
Old Dec 30, 2004 | 04:44 AM
code3's Avatar
code3
Does a 98 D have a self test to spot errors/problems??
