need favor - Please measure shock length: 2wd or 4wd
Old Aug 3, 2004 | 05:05 PM
85258x's Avatar
85258x
Default need favor - Please measure shock length: 2wd or 4wd
Can someone please measure the length of their shocks (front and rear) while their truck is sitting on a flat surface and post it here. For the rear, measure from center of top bolt to center of bottom bolt. For the front, measure from the lower part of the top mount to the center of the bottom bolt.
Please note year & model of your Durango.
Why?
I have custom lowered my '04 Dakota QC 4x4 and I am trying to find shocks to go with my lower ride hieght. I am wondering if stock Durango shocks have a shorter stroke/lower ride hieght than stock Dakota shocks.
Thank-you in advance!
Old Aug 3, 2004 | 05:59 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Default RE: need favor - Please measure shock length: 2wd or 4wd
https://dodgeforum.com/fb.asp?m=62356
He'd like measurements from both the Dakota AND Durango... that's why this is posted twice.
~Amanda
Old Aug 3, 2004 | 09:40 PM
rockadaous's Avatar
rockadaous
you don't want stock shock heights for a lowered quad. you'll bottom out or do you plan on subtracting the drop measurement from the stock measurement? does that make sense???
ORIGINAL: Dodgegirl19
~Amanda
Old Aug 4, 2004 | 02:34 AM
85258x's Avatar
85258x
I guess I could have been more clear...
I edited my original post. I am looking for the length of stock durango shocks to compare them to my lowered ride hieght in my Dakota 4x4. If Durango shocks are shorter stroke/lower ride hieght I might try a set.
Old Aug 4, 2004 | 03:38 AM
rockadaous's Avatar
rockadaous
why not throw some toxic shock in there? specially designed for lowered applications
Old Aug 4, 2004 | 06:28 AM
bergjw's Avatar
bergjw
Durango 2004 5,7 hemi rear length 61 cm center to center bolts complete out
length 42 cm center to center bolts complete in
Old Aug 4, 2004 | 01:41 PM
85258x's Avatar
85258x
rockadaous: What are toxic shocks? Do they make lowering shocks for Dakota 4x4?
Bergjw: Thanks fo those lengths, I guess you are measuring the shock when not installed? I was hoping to get the static ride height with the shock installed.
Old Aug 4, 2004 | 06:52 PM
bergjw's Avatar
bergjw
measurd the shocks when not installed.
Made new ones for my durango for the rear.
adjustable in and outgoing.
a friend is working by WHITE POWER shocks in germany.
within 1 month i do also the front shocks
i can tell all the DURANGO drivers the car is steering 100 % better
half and full loaded
best regards
Old Aug 5, 2004 | 05:36 AM
rockadaous's Avatar
rockadaous
ORIGINAL: 85258x
http://toxicshocks.com/pages/dodgeapps.html
http://www.stylinconcepts.com carry em
