Heater Core?
Old Jan 17, 2007 | 04:14 PM
ccusum's Avatar
ccusum
Default RE: Heater Core?
ORIGINAL: 2000RT
ORIGINAL: jonnymagnum
you probly have a plugged heater core. here is a post on how to flush your heater core.
https://dodgeforum.com/m_640588/tm.htm
+ 1 on Jonny's solution. I did it, and the heater was like new!!
BTW this is very easy
I did poke around the engine bay when I found this. hoses are right on top right where the pics show. can't wait to do this. Getting excited!!!!!
Old Jan 18, 2007 | 04:27 PM
Kensai's Avatar
Kensai
Just remember after you flushed your core and the heater is spewing heat back into your cabin, PLEASE check your coolant and radiator itself and have that thouroughly flushed as well. If your heater core is plugged up, it is a indication that your cooling system is contaminated and have debris build up. I would recommend you to check the rest of your cooling system otherwise your heater core will just get plugged again shortly or problems starting somewhere else in your cooling system.
Old Jan 18, 2007 | 07:28 PM
ganzhimself's Avatar
ganzhimself
I think I'm just going to bite the bullet and go to a service shop and get the whole system flushed... It's probably over due anyway, even though the previous owner said regular maint. was done...
Old Jan 18, 2007 | 10:39 PM
Kensai's Avatar
Kensai
That would be the way to go to have your cooling system thouroughly flushed and inspected! Hate to see another piece of your cooling system fail down the road.
Old Jan 18, 2007 | 10:49 PM
Kensai's Avatar
Kensai
I also stickied this to the top as the heater core will be the most sought after item in the winter.
Old Jan 19, 2007 | 09:33 AM
ccusum's Avatar
ccusum
Well, I did this and it took me longer to get the hose out and hooked up then it did for me to flush the core. Why can't all fourms that people ask for help be this easy?
Old Jan 22, 2007 | 05:32 PM
ganzhimself
Just got back from the shop, I had the whole cooling system flushed and now I have heat again!
Old Jan 23, 2007 | 06:29 PM
Chris's Avatar
Chris
Also, you can flush your entire cooling system using this same method, only using the lines running to and from the radiator. It will take longer, but will ensure that you have gotten any debris that was causing problems. I would suggest doing the heater core and radiator/block flush at the same time.
Old Jan 29, 2007 | 01:43 PM
Lianimal's Avatar
Lianimal
Great advice folks! Did the whole cooling system this weekend and the heat is warmer than ever.
Old Jan 30, 2007 | 04:16 AM
2000DirtyDurangoDD's Avatar
2000DirtyDurangoDD
ORIGINAL: ganzhimself
I've noticed that the heater in my 98 Durango takes a very long time to heat up. If I let my D warm up for 10 minutes before I leave, the heater blows warm, but not hot. It may take 20+ minutes of total run time to get hot air. Could this be a problem with the heater core? I don't know much about that kind of thing, so if anyone could point me to the root of the problem, I'd appreciate it. If it is the heater core, I founda heater core from a 99 Durango (same engine size as mine, 5.2L w/ AC), and I was wondering if it would be a suitable replacement for the heater core of my 98 with the 5.2L.
I have the same problem,I read the thread and did the flush,the water turned clear in about 3 seconds,still not much heat,now what?
P.S. I called the local Dodgestealership an asked about the heater core flush.It is 2 degrees here and I wanted a price on them doing a flush.The guy told me he wants to meet the person who can flush a heater core in 15 minutes,he said the hoses are real hard to get at,takes at least 2 hours..I'm going over tommorrow to meet him.Ha ha!
