Heater Core?
Old Jan 16, 2007 | 08:35 PM
ganzhimself's Avatar
ganzhimself
Default Heater Core?
I've noticed that the heater in my 98 Durango takes a very long time to heat up. If I let my D warm up for 10 minutes before I leave, the heater blows warm, but not hot. It may take 20+ minutes of total run time to get hot air. Could this be a problem with the heater core? I don't know much about that kind of thing, so if anyone could point me to the root of the problem, I'd appreciate it. If it is the heater core, I founda heater core from a 99 Durango (same engine size as mine, 5.2L w/ AC), and I was wondering if it would be a suitable replacement for the heater core of my 98 with the 5.2L.
Old Jan 16, 2007 | 08:40 PM
LayItLowS10's Avatar
LayItLowS10
Default RE: Heater Core?
i have the same problem, although mine really doesnt get too hot at all.
Old Jan 16, 2007 | 08:58 PM
jonnymagnum's Avatar
jonnymagnum
you probly have a plugged heater core. here is a post on how to flush your heater core.
https://dodgeforum.com/m_640588/tm.htm
Old Jan 16, 2007 | 09:03 PM
ganzhimself
I guess "hot" wasn't really the right word to use, because the air isn't really all that hot. It's no where near as warm as the heat in any of my friends' vehicles.
Old Jan 16, 2007 | 09:07 PM
ganzhimself
Wonderful. Thank you. I'll have to stick it out for the remainder of the winter, but as soon as it gets warm enough to actually work outside I'll have to do this.
Old Jan 16, 2007 | 09:50 PM
LayItLowS10
thanks for the how-to. ill be doing that this weekend.
Old Jan 17, 2007 | 12:28 AM
ccusum's Avatar
ccusum
Oh this is great. I have been having the same issue as stated above. To bad it is 15 degrees out side or I would be out there right now doing this. Going to have to wait till Thursday for me to take a crack at this.
thanks I will elt you know.
Old Jan 17, 2007 | 02:07 PM
2000RT's Avatar
2000RT
ORIGINAL: jonnymagnum
+ 1 on Jonny's solution. I did it, and the heater was like new!!
BTW this is very easy
Old Jan 17, 2007 | 02:09 PM
jonnymagnum
thank virused he did the write up on it.
Old Jan 17, 2007 | 02:33 PM
ganzhimself
If it was a bit warmer than 5 degrees out right now, I'd be doing this. Thanks for letting us know that it works well.
