Trans slip - cold
Old Jan 21, 2007 | 10:49 PM
Denver Dodge's Avatar
Denver Dodge
Default Trans slip - cold
Hi all,
I have a 2001 R/T that just had a transmission rebuild a month ago. It is nice and solid except when the weather is cold (<32F). Untill you dive a few miles it slips (clunks into gear from a stop). I thought the rebuild would have fixed this. Am I missing a sensor problem or something?
This is my first Durango after driving Ramchargers (5 of them) and couldn't be happier![sm=drooldude.gif]
Old Jan 22, 2007 | 05:30 AM
Mean Green's Avatar
Mean Green
Default RE: Trans slip - cold
Get them to fix it and on a side note if you haven't already you will want to replace the radiator. When the tranny goes it takes the radiator with it in these and will give you a lot of problems later without a new radiator. Do a search on here for "tranny" and you will find an old post of mine about it. I have also put the link ina recent post around here somewhere...
Old Jan 23, 2007 | 12:51 PM
hydrashocker's Avatar
hydrashocker
This is no normal. It sounds like a weak pump or a bad band. Take it back and have them fix it.
