Just wondering ?
Old Jan 25, 2007 | 07:53 PM
BAD 02 R/T's Avatar
BAD 02 R/T
Default Just wondering ?
I was just wondering why my service 4 wheel drive light is on , what would make that come on ??and i did a complete tune up on my r/t and I noticed a little oil on the # 8 spark plug . what could it be also??
Old Jan 25, 2007 | 11:13 PM
HeavyD's Avatar
HeavyD
Default RE: Just wondering ?
not sure about the 4 wheel drive light
As for the oil. look into the Trottle body with a flash light and see is you can see any oil down in the intake. The beer keg style intake your running has had problems with gasket leaks on the bottom of the intake. If the inside bottom of the intake is coated with oil the gasket is most likely bad. This is where you should start first.
Old Jan 26, 2007 | 01:51 PM
Mean Green's Avatar
Mean Green
^yup intake plenum gasket is the first place to look.
Old Jan 27, 2007 | 07:58 PM
BAD 02 R/T's Avatar
BAD 02 R/T
thanks 4 the info .. i hope thats all it is and not the oil ring in the piston ..
Old Feb 7, 2007 | 12:26 PM
billdrohan's Avatar
billdrohan
The 4 whhel drive service light for my 2 wheel drive vehicle is caused by the AC contraller switch. Pretty good design there huh. Dodge won't cover the repair. Cost is about 250 for the part and 2 hours labor.
Old Feb 7, 2007 | 12:48 PM
hydrashocker's Avatar
hydrashocker
But like he said he has the R/T which has All Wheel Drive.
It could be a wheel sensor.
Old Feb 7, 2007 | 04:49 PM
n8ech's Avatar
n8ech
Bad 0 RT:
If that happened to my 01, I would be inclined to cycle the dash trasfer case switch through all of its positions in hopes that a sensor in that realm was dirty, or maybe something just needs to be properly seated.
I do not think it could hurt, and it might cure the issue.
You might also try a battery disconnect reset to see if one of the many computers has gotten a glitch.
Old Feb 9, 2007 | 12:41 AM
BAD 02 R/T's Avatar
BAD 02 R/T
Default NOT RIGHT ??!!
I got another prob ?? for some reason my oil keeps needing a quart low every 2-3 weeks .. I dont know if its cause of the intake prob or something else is major wrong .. Also i noticed that my coolant is low too??? but there is no smell of coolant in the truck or outside of it , and no leaks that are visible ...?? Any HELP would be great .. ohhh is doesnt run Hot at all..
Old Feb 9, 2007 | 09:08 AM
Mean Green's Avatar
Mean Green
Default RE: NOT RIGHT ??!!
Your t-stat is probably stuck open. It will run very cool especially on the freeway like that.
