transmission shifting
Old Aug 29, 2004 | 05:08 AM
easystroke's Avatar
easystroke
Default transmission shifting
I have a 99 durango that has just started shifting funny. It is only between 1 & 2 gear. Sometimes it shifts fine other times it acts like it slips when shifting. I read a few other post about the speed sensor but I don't have any check lites coming on. Any suggestions.
Thanks,
easy
Old Aug 29, 2004 | 03:40 PM
rockadaous's Avatar
rockadaous
Default RE: transmission shifting
sounds like your dead on. I've read other people had the same problem with no lights. It's worth a try. http://www.autoclinic.net welcome to the boards
Old Aug 30, 2004 | 12:35 AM
easystroke's Avatar
easystroke
I replaced the speed sensor and it did seem to help with the shifting but it still doesn't feel totally right. Sometimes it wants to downshift right after it shifts from 1st-2nd when its under a good load. If I'm driven normal , it seems to do fine. The guy at autozone said there was a primary speed sensor but it was out of stock. I wonder if it is because alot of people are replacing them? Are there anymore sensor that I should be looking for?
Old Aug 30, 2004 | 10:50 AM
rockadaous's Avatar
rockadaous
TPS throttle position sensor. grey sensor on the throttle body. usually with the speed sensor your speedometer goes out too.
Old Sep 1, 2004 | 02:07 AM
easystroke's Avatar
easystroke
I have changed both the speed sensor and throttle position sensor with no luck. Any other suggestions?
Old Sep 1, 2004 | 10:15 PM
Kensai's Avatar
Kensai
My transmission went to limp mode after pulling a uhaul trailer (this was a small single axle trailer with only 1 sofa in it) for a couple of days. After dropping off the trailer back to Uhaul, the transmission never shifted like it used to. Seems like I was always pulling something and also the transmission seems to shift when it should not. Eventually on the 2nd day after I pulled that trailer, the check engine light came on and my transmission would not leave 1st gear.
Dealer check and then had to replace the governor switches. Re-flashed my PCM which is covered under emmissions warranty. Looking at my service receipt, there was a TSB on the PCM. It says "FLASH PCM PRE TSB 18-006-03".
This was for my 2000 Durango R/T.
Since then, and after replacing the Throttle position sensor, the R/T shifts and runs really great.
Old Sep 2, 2004 | 02:35 PM
easystroke's Avatar
easystroke
Is there anyway that you can flash the PCM yourself or do you have to take it to the dealership for that. I am looking at replacing the governor transducer first to see if that helps.
Old Sep 2, 2004 | 05:10 PM
Kensai's Avatar
Kensai
I don't know if you can flash the PCM yourself without having to buy some electronic hardware kit that can interface itself to the PCM. Problaby would cost you more to buy the hardware to flash it than having the dealer flash it for ya. You can problaby check with a reputable Dodge dealer and ask if your 1999 Durango has any TSB's on your PCM. IF so, you can get your PCM flashed without any cost to you. My dealer says that the updated flash on the PCM affects emissions and I think emissions has a 10 year 100k warranty??? not sure. But mine was covered under emissions.
Old Sep 6, 2004 | 03:04 AM
AndrewH's Avatar
AndrewH
Friend had the same problem with a 1999 dakota 5.2 and the governer sensor change out fixed the problem.
Old Oct 2, 2004 | 03:48 AM
DodginLife's Avatar
DodginLife
where is the governor sensor located at??
