99 Durango overheating....
Old Mar 25, 2007 | 04:25 PM
Durango_USMC's Avatar
Durango_USMC
Default 99 Durango overheating....
As usual once i fix something, another thing goes wrong. well I have the problem of the Durango overheating at idle. I've looked around the forums and I am assuming it's one or a combination of things. The first being a fan of some sort that is suppossed to click on at certian temperatures? Then the battery doing some sort of funky mumbo jumbo but I don't usually have a problem with that. Possibly the oil because I'm slightly overdue for a change. Lastly the thermostat. When the head gasket and two cylinderheads blew a little over a year ago due to a thermostat issue the mechanic replaced the thermostat with one this is suppossed to stick open if there's a pressure drop? I'm barely mechanically literate when it comes to these kinds of things. I'm a weapons tech not a mechanic unfortunitely. If anyone has any insite into the matter I'd appriciate it, I'm stuck in Indy so if anyone wants to take a look at it I'd probably be willing to open up a spot in my schedule. Any help is appriciated. The AC doesn't work either if that has anything to do with it.
Semper Fidelis
PS: It's a 5.9L 4x4 with 127xxx miles on it.
Old Mar 25, 2007 | 10:19 PM
Mean Green's Avatar
Mean Green
Default RE: 99 Durango overheating....
I'd suggest a good flush first off then after that I'd look at your fan andt-stat (again go with jet or OEM no autozone specials they fail every other time).
I am about 99% sure it is your fan because you said it only starts overheating at idle which is pretty much the only time you need your fan really. I have also had a t-stat get stuck halfway open and at idle it would begin overheating because the coolant wasn't flowing fast enough but when I revved my engine it would drop back down because of the increased pressure forcing the water through faster. Both of these fixes are very easy and if you picked up a chiltons or haynes manual you would have no problems at all.
Old Mar 25, 2007 | 11:11 PM
MAGIC84's Avatar
MAGIC84
USMC, I am in Indy, Always willing to help out a Fellow Devil Dog if able. I will send you a PM with contact info, I am not the best with real in depth repairs, but I might be able to take a look and see if it is something obvious. I am Former USMC 96-99 AIRWING MCAS BEAUFORT, SC Semper Fi!!
