1st Gen Intrepid 1993 through 1997 Intrepids
Turn Signals Don't Flash...HELP please
Old Jun 27, 2009 | 11:02 PM
suzukiGSXR's Avatar
suzukiGSXR
Default Turn Signals Don't Flash...HELP please
Ok my 97 Dodge Intrepids turn signals just went out and I got a R&R ticket the other day. The warning lights turn on, however the turn signals or the hazards do not work, and all 4 of them went out at the same time.
I have checked the fuses, the flasher unit, and replaced the turn signal switch lever. None of which fixed the problem. If anyone has any idea's what it could be that would be great. I was looking at the wire diagram today, but didn't find anywhere that could effect this.
Thanks,
Adam Drumm
Old Jun 28, 2009 | 12:17 AM
lennemann23's Avatar
lennemann23
Sounds like you lost your voltage coming into the turn signal switch unit its self. If you have a volt meter you can check the voltage coming into it and coming out of it. I have a manual that I can copy pictures of wiring diagrams if you would like. If so hit me up at lennemann23@yahoo.com
P.S. Check out my post and see if you can help me on my stuff dude, because I'm stuck.
