Bad Fuel Efficiency? 1997 Neon
Hi,
i was wondering if my 97 neon has bad gas mileage. I get about 400km on a tank (47L)
I changed my egr valve thinking it would make a difference, and i havent noticed any difference yet.
If this is a bad fuel to milage ratio, what can i do to use less gas?
i have an automatic.
from this website: http://www.1728.com/convmlge.htm
i got a gas mileage of 21.383 miles per US gallon.
seems low?
seems low?
21 mpg seems low for a Neon, unless you are doing all city driving then I could see that being possible.
If you are doing a mix of city and highway that seems low to me. Are you throwing any codes? Have you not done a tune up in a while (plugs, wires, air filter, fluids, etc)? Have you not done an alignment in a while? Are you tires properly inflated?
what gutted said! youd be amazed at what little things can do to our cars? also whats the history on your engine?do you change your oil regurly?past engine problems could result in low gas mileage. also how many miles on your car?
