dohc swap questions
Old 04-09-2007, 12:07 AM
pssssst's Avatar
pssssst
pssssst is offline
Default dohc swap questions
ok dont rip into me cause this topic has been covered... i know it hasbut i need to know some other stuff... first of all... can i just swap the heads only?? secondly, will i be able to use my sohc gauges with no tach still with the dohc head swap?third, and will i need the comp out of the dohc car???? thanks ever1
Old 04-09-2007, 12:18 AM
johnneon's Avatar
johnneon
johnneon is offline
Default RE: dohc swap questions
this should help u out,,good luck,
https://dodgeforum.com/m_599520/tm.htm
Old 04-09-2007, 01:56 AM
das2123's Avatar
das2123
das2123 is offline
You can't swap just the heads.
Old 04-09-2007, 01:59 AM
neoncrazy101's Avatar
neoncrazy101
neoncrazy101 is offline
ORIGINAL: das2123
dont u also have to swap the pistons, valve cover, hood(if you dont have a powerbuldge hood, or gutt the supports), intake manifold and the exhaust manifold?
Old 04-09-2007, 02:14 AM
racerx55's Avatar
racerx55
racerx55 is offline
you dont HAVE to swap the pistons, but you will lose performance instead of gaining anything from the lower compression, that would befine if you were putting a turbo on with it
Old 04-09-2007, 10:39 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
spark plug wires....passenger side motor mount plate....intake manifold....exhaust manifold...valve cover..and a few others
Old 04-09-2007, 11:49 AM
das2123's Avatar
das2123
das2123 is offline
Spud, you can use DOHC wires on a SOHC right? Just not the way other around, correct?
Old 04-09-2007, 04:01 PM
spudsterier
the neck of the sohc wires are a slight bit longer....you could use them but they wont seal on the valve cover properly.....if you were to wash your engine for example, you would fill the spark plug tubes with water...
the neck of the dohc wires might be too short to reach the plugs.....i would check it, but out of 4 neons i dont have a sohc
Old 04-09-2007, 04:26 PM
das2123's Avatar
das2123
das2123 is offline
I'm not gonna do it, just curious.
Old 04-09-2007, 07:14 PM
spudsterier
ive got some nice sohc plug wires in the garage.....i tried putting them on the r/t but they are too long....so they just sit in a box and i have to buy new ones for the r/t
Quick Reply: dohc swap questions
