okay, im heavily considering sticking with the sohc and buying a performance rebuild kit for it. i was lookin at modernperformance and they have a sweet turbo rebuild kit which is what i plan on doing... i am also going to get the mopar pcm, is it going to still work even though the compression and everything has changed????i was jw if anybody has used this kit and what kind of results you are having as far as boost levels your running, durability, hp numbers... thanks every1
are you trying to say im going a cheap route?? lol im not trying to be cheap im just going to do my own turbo set-up without getting ripped off at the same time
