Stratus Engine Parts MIA?
Old Apr 18, 2007 | 10:45 PM
dirty neon r/t's Avatar
dirty neon r/t
Default RE: Stratus Engine Parts MIA?
Thanks for all the help, if I have later questions, i'll be sure to write back! Thanks!
Old Apr 18, 2007 | 11:38 PM
dirty neon r/t
Actually I do have another question....do I need a new ECU when I do the engine swap or can I just use my current one?
Old Apr 18, 2007 | 11:43 PM
BadBrads97Neon's Avatar
BadBrads97Neon
You can use your stock pcm. It will be fine with the 2.4
Old Apr 19, 2007 | 02:15 AM
das2123's Avatar
das2123
You need a DOHC PCM.
Old Apr 19, 2007 | 02:17 AM
BadBrads97Neon
Does he have a SOHC?
Old Apr 19, 2007 | 02:28 AM
das2123's Avatar
das2123
ORIGINAL: BadBrads97Neon
Don't know, but just clarifying.
Old Apr 21, 2007 | 12:20 AM
dirty neon r/t
I currently have 2.0 Cam Gears that I had bought previously....Will I be able to use them with the 2.4 engine? I also have a underdrivepulley, can I use that as well?
Old Apr 21, 2007 | 01:04 AM
das2123's Avatar
das2123
I believe you can use the UDP, but not the cam gears.
Old Apr 21, 2007 | 01:15 AM
dirty neon r/t
So why would 2.0 Cams fit but not the Cam Gears? Also, if I bought an SRT 4 valve cover, would it fit on the 2.4 Stratus engine?
Old Apr 21, 2007 | 01:21 AM
das2123's Avatar
das2123
OK, if you are using 2.0 cams then yes.
I believe the valve cover fits.
