Stratus Engine Parts MIA?
Old Apr 21, 2007 | 03:25 PM
  #21
dirty neon r/t's Avatar
dirty neon r/t
Default RE: Stratus Engine Parts MIA?
The engine I ended up getting was a 98 instead of a 96....is that okay? THe alternator is in the front and my original is in the back, is that still gonna hook up?
Old Apr 21, 2007 | 04:09 PM
  #22
das2123's Avatar
das2123
You got a '98 2.4L engine? If so, you're good. Here is some more/better info
Yes the 2.0 and 2.4 heads are the exact same head. They are the same casting number. The difference is the cam gears and the cams. You can use a 2.0 exhuast cam on your 2.4 motor and gain some HP. You must use 2.4 cam gears. Do not change the 2.4 intake cam. I will repeat the 2.0 and 2.4 heads are the same heads and can be used on either motor!!!
Old Apr 22, 2007 | 06:20 PM
  #23
dirty neon r/t
My Neon redlines stock at 7000 rpm but the stratus redlines at 6250 rpm....does that make a big difference or is that okay? Thanks
Old Apr 23, 2007 | 11:20 AM
  #24
das2123's Avatar
das2123
Rev limiter is controlled by the PCM and you will be using the DOHC neon PCM.
Old Apr 23, 2007 | 08:55 PM
  #25
dirty neon r/t
Yeah I know that, but will the engine be able to hold up to the new redline at 7k?
Old Apr 23, 2007 | 10:45 PM
  #26
dirty neon r/t
Also, the underdrive pully I haqve, you said it should work but when I compared it to the stock stratus UDP, it was much smaller. It doesn't look like it will work. Will it throw off the engine balance? Thanks!
Old Apr 24, 2007 | 02:03 AM
  #27
das2123's Avatar
das2123
ORIGINAL: dirty neon r/t
Yep, it will be fine.
Also, the underdrive pully I have, you said it should work but when I compared it to the stock stratus UDP, it was much smaller. It doesn't look like it will work. Will it throw off the engine balance? Thanks!
Its also smaller than the stock neon pulley.
Old Apr 24, 2007 | 02:08 AM
  #28
BadBrads97Neon's Avatar
BadBrads97Neon
^^^most udp's are smaller lol
Old Apr 24, 2007 | 10:41 PM
  #29
dirty neon r/t
yeah I know, but it looks backwards as well that's why I am asking......because the pulley is on the block of the engine?
