FUSE BOX
Old Apr 18, 2007 | 11:08 PM
boxerjl2's Avatar
boxerjl2
Default FUSE BOX
Hello Im Having Problems Every Once In A While
With The #2 Fuse "Park Lamps" The One That Powers The Lights On The Cluster
well ipopped off the topdash and looked at all the wires and unscrewed the fuse box and all the wires seem to be fine and i plugged a fuse in and it worked just fine nothing wrong all day then tonight i get in my car and start it up turn on the headlights and popped that fuse and it does it everyonce in a while actually like everyday and the miny blade fuses ARNT very cheap
any reason why i would be blowing this so often ? could it have something to do with the Cd Player??
Because i dont know just let me know waht you think Thank You
Josh
Old Apr 19, 2007 | 12:31 AM
neisg1's Avatar
neisg1
Default RE: FUSE BOX
OK, fuse #2 is a 15 amp that feeds the park lamps and also the black/yellow wire to the radio so- yes it could be related to your CD player. Fuse #2 also feeds the dash illumination lights through a dimmer and fuse #12 a 4 amp. Is your Cd player an after market? If it is you may be drawing power from black/yellow rather than from the red/white wire.
Old Apr 19, 2007 | 02:17 AM
boxerjl2's Avatar
boxerjl2
thank yuo i think it is the cd player becuz i didnt have the problem till i unhooked the old cd player and put in my pioneer
Old Apr 19, 2007 | 02:37 AM
neisg1's Avatar
neisg1
Is this the same car you had the speedometer-dash-cluster smoke problem and the engine code problems?Just wondering if it might be a related problem?
Old Apr 19, 2007 | 03:47 AM
boxerjl2's Avatar
boxerjl2
yeah its the same car the reason it was smokin was becuz i put a 30 amp fuse were its suppose to be a 15 becuz it kept blowing but it just fine
i gots a question how come there are 2 fuses that control the dash lights??
#2 and number #12
i think i figured out the problem with the blowing fuse,I re-hooked up the cd player.
only timeCan tell though
ill check it out tomorrow
let me know about the fuses #2 and #12
i couldnt get my cd player to turn onand i had the battery wire and the ignition wire for cd player open wired and they touched and everything came on including my dome light which wouldnt come on so ill see whats going on
haha
peace
Josh
Old Apr 19, 2007 | 03:49 AM
boxerjl2's Avatar
boxerjl2
actually you already talked about #2 but what about #12
Old Apr 19, 2007 | 04:22 AM
neisg1's Avatar
neisg1
The main fuse #2 is a 15 amp that feeds the park lights it then branches off through the dash light intensity control andthrough fuse #12 a 4 amp to feed the dash illumination lights.
By the way that short may have glitched the PCM, I would try resetting it and see if the codes come back or not. It’s worth a try.
Old Apr 20, 2007 | 02:18 AM
boxerjl2's Avatar
boxerjl2
i really no next to nothing about cars i love them but no nothing i am trying to learn and i am slowly with this forums help but how do i reset the PCM
oh and i blew the fuse again [>:]
so im really at a loss
Old Apr 20, 2007 | 02:48 AM
neisg1's Avatar
neisg1
To reset the PCM just disconnect the neg. battery cable for about 10 min.and then reconnect, this should reset the codes and the check engine light should then be off. If there is still a problem the codes will come back.
As far as the fuse blowing I would try disconnecting the cd player for a while and see if it still blows the fuse. If it still blows the fuse then I would suspect a short in the park light wiring. The black wire with a yellow stripe is the one connected to this fuse.
Note: if you have remote keyless entry the the same black wire with a yellow stripe feeds power to it as well.
Old Apr 20, 2007 | 03:02 AM
iwalton63's Avatar
iwalton63
take out your cd player and make sure that all the wires are covered up good.
through some wire nuts on them. just make sure that none of the wires are touching metal.
mine was doing that same thing and it was because one of the wires was touching metal.
