Gas Tank Problem
Old Apr 19, 2007 | 12:53 PM
das2123's Avatar
das2123
Default RE: Gas Tank Problem
ORIGINAL: spudsterier
if it has a metal tank....there is a drain nipple on the lower portion of the pump that usually has a plug on it...that plug tends to rot out after a while causing a leak....
That's where my ACR was leaking from...easy fix
Old Apr 19, 2007 | 03:56 PM
spudsterier's Avatar
spudsterier
ORIGINAL: das2123
i remember
