UHHHHHHHHHHHHHHH, HELP!!
Old Apr 20, 2007 | 02:43 AM
NEONRT98's Avatar
NEONRT98
Default RE: UHHHHHHHHHHHHHHH, HELP!!
I've come to the conclusion... I am going to store Das in my toolbox... I wouldn't ever have to look anything up ever again!
Old Apr 20, 2007 | 12:08 PM
spudsterier's Avatar
spudsterier
the wire harness would of worked fine for you....IF it would of been from the same year as your car.....
alot of 97's have most of the same plugs as the 95 and 96's.......but 98 and 99 are compatible between eachother.....
the wire harness on the 97 is kinda a half breed between all the years...
the 97's plugs for the coil pack, cam sensor, oil sending unit, crank sensor, map sensor, and cts are the same as 98-99 neons..
the 97's plugs for the alternator, starter, fuel injectors, vss, tps, and iat are the same plugs as 95-96 neons
just f.y.i.
Old Apr 20, 2007 | 06:56 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Lol, now you tell me. Well, I think what I will have to end up doing for the fuel injectors is take the injector harness and splice it further down rather than try and splice all four plugs on. It is not that big of deal, but when I was getting it I was hoping I would be able to sorta do a plug and play kinda siteation lol. Everything else I have spliced, but man, why did they change so many things so many times???
Old Apr 20, 2007 | 08:42 PM
Jr. Mechanic
Oh, and one more thing, I was talking about the plug for the VSS, not the whole sensor.
Old Apr 21, 2007 | 12:57 AM
spudsterier
it would of been plug and play...if the harness would of been from another 97
Old Apr 21, 2007 | 12:26 PM
Jr. Mechanic
Yeah, but I did say it was from a 98 going to a 97... Im not blaming anyone though.
