UHHHHHHHHHHHHHHH, HELP!!
Old Apr 19, 2007 | 06:51 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default UHHHHHHHHHHHHHHH, HELP!!
Ok, Well, I got my wiring harness today and well, there are more differences than you guys stated. Here are the things I can handle:
1. CTS wire (which I already new about)
2.MAP sensor wire is not long enough, I can just splice that.
3. Single brown wire to the starter is different on the end, mine just has a single female flat plug.
Things I am not sure about:
1.Fuel injector plugs are different shape and do not fit my injectors. (Same color wires)
2. TPS plug is different (same color wires)
3.IAC plug is different (same color wires)
And this is what I have found after a quick look through, my question is can I somehow take the plugs off and switch them without cutting the wires, or do I have to buy the sensors and fuel rail from him? PLEASE HELP ASAP!!!!!!!
Old Apr 19, 2007 | 07:41 PM
Jr. Mechanic
Default RE: UHHHHHHHHHHHHHHH, HELP!!
Anybody!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 19, 2007 | 07:53 PM
das2123's Avatar
das2123
Refresh me, you have a 97 SOHC and what kind of harness did you buy?
Old Apr 19, 2007 | 08:42 PM
Jr. Mechanic
I got the harness from a 98 DOHC engine, I also just found that the alternator and VSS are different, by the way, how do you get the VSS off? Mine is the gray three plug one, the one on the new harness is a black one like the coilpack and cam sensor and such. HELP ASAP!!
Old Apr 19, 2007 | 09:41 PM
NEONRT98's Avatar
NEONRT98
If all else fails, you *can* just splice in the old connectors, just make sure they are secure splices!
Old Apr 19, 2007 | 10:00 PM
Jr. Mechanic
yeah, I am doing that right now, it isnt as bad as I thought it would be, I did alternator plug and TPS. But again, HOW DO YOU GET THE VEHICLE SPEED SENSOR OFF!!
Old Apr 19, 2007 | 11:38 PM
das2123's Avatar
das2123
The VSS is held on by (1) 10mm bolt.
Old Apr 19, 2007 | 11:54 PM
BadBrads97Neon's Avatar
BadBrads97Neon
^^^ Das you are one walking, talking Neon FSM. lol
Old Apr 19, 2007 | 11:59 PM
Jr. Mechanic
Where is the bolt? We are both talking about a auto, right? I guess I didnt look the best, but I dont think I saw a bolt. Anyways, So far I have the IAT sensor, TPS sensor, and alternator spliced and taped, but grrr, I ran out of splicers lol. I think I will be able to get it to work fairly well, But, Didnt you guys tell me it would be a direct fit except for the CTS?????
Old Apr 20, 2007 | 01:09 AM
das2123's Avatar
das2123
This pic should help for the VSS...
