Ebay intake check it
Old Apr 22, 2007 | 05:58 PM
QuiK615's Avatar
QuiK615
Default Ebay intake check it
http://cgi.ebay.com/ebaymotors/95-96...QQcmdZViewItem
looks like itd work to me
Old Apr 22, 2007 | 06:10 PM
das2123's Avatar
das2123
Default RE: Ebay intake check it
I wonder if you could route that underneath the battery tray? I would like to know the length of piping.
Old Apr 23, 2007 | 12:01 AM
spudsterier's Avatar
spudsterier
from the looks of it, the filter still sits right above the exhaust manifold
Old Apr 23, 2007 | 02:47 AM
boxerjl2's Avatar
boxerjl2
ive got a question one of my friends say i should get the Flexi pipe for the intake and cut a hole in the piece of metal next to the radiator so it can get cold air because right now its mounted behind the engine and it cant be picking up to much cold air there
let me know what your thinking
Old Apr 23, 2007 | 11:25 AM
das2123's Avatar
das2123
Anty intake that puts the filter above the exhaust manifold isn't gonna yield you much power at all. You may see a drop in power actually. The filter needs to be located towards the front of the engine under the battery tray.
Old Apr 23, 2007 | 11:34 AM
spudsterier
or behind the front facia
Old Apr 24, 2007 | 12:55 AM
boxerjl2's Avatar
boxerjl2
ok does the pipeing have to be metal or can you use like dreyer hose the flexi hose. cuz i was thinking about putting it by the radiatior?? is that a good place??
or maybe ill put it under the battery
let me know
Old Apr 24, 2007 | 01:02 AM
spudsterier
you can basically use anything for pipe
Old Apr 24, 2007 | 01:27 AM
boxerjl2's Avatar
boxerjl2
ok just want to loose any performance so by mooving the the filter i can increase some performance??
how often should the filter be replaced?? are all the filters the same right now i have the K&N But does it really Matter the brand?
Old Apr 24, 2007 | 01:28 AM
spudsterier
k&n would be the best to use in almost any car....
really the only way to loose performance with a cai iis by placing the filter by a heat source
