cross bars in back and info on strut tower bars
Old Apr 25, 2007 | 12:03 AM
tandc972003's Avatar
tandc972003
Default cross bars in back and info on strut tower bars
I need to find out if you con replace the rubber bushings in the two cross bars on the rear axle not sure what the are called and strut tower bars are they worth it do they help at all on a car this small
Old Apr 25, 2007 | 12:32 AM
das2123's Avatar
das2123
Default RE: cross bars in back and info on strut tower bars
Strut bars won't help performance, but are nice to look at.
You can replace the bushings.
Old Apr 25, 2007 | 12:38 AM
tandc972003
thank you I was wanting to know about the strut bars I have a 1984 camaro they helped on it but its alot heavier then a neon it helped off the line
Old Apr 25, 2007 | 12:42 AM
formula21's Avatar
formula21
why dont the strut bars help much or do they just not help with performance but help with handling
Old Apr 25, 2007 | 12:49 AM
das2123's Avatar
das2123
They do help body roll some and make the car stiffer. So I wouldn't say they are worthless on the neon, but don't expect drastic improvements. A rear sway bar on the other hand will make a difference.
If you do buy strut bars, make sure they are adjustable so you can preload them and make the car stiffer.
Oh, and get your alignment checked after ANY suspension work.
Old Apr 25, 2007 | 12:56 AM
tandc972003
I was told when I got them for my camaro during take off or high Torque the una body flexes the strut bars help reduce that flexing giving you more control
Old Apr 25, 2007 | 01:02 AM
formula21's Avatar
formula21
did the rt and the acr come stock with a sway bars and are they the same or dif
Old Apr 25, 2007 | 01:06 AM
spudsterier's Avatar
spudsterier
ORIGINAL: formula21
the r/t's and acr's both have rear sway bars that are slightly larger then the other neons with them....
r/t's and acr's share most of the same suspension parts...
anyone need a rear sway bar??? i have 2 or 3 of them hanging in the garage
Old Apr 25, 2007 | 05:48 AM
95neonriceeater's Avatar
95neonriceeater
are rear sway bars hard to put on?
Old Apr 25, 2007 | 08:53 AM
HabitatHxC's Avatar
HabitatHxC
ORIGINAL: 95neonriceeater
X2
If i can just put it on with some time, i could probably use them! So DIBS!
