wheel bearing question? new question!
Old May 3, 2007 | 06:41 PM
johnneon's Avatar
johnneon
Default wheel bearing question? new question!
ok if i have a good tie rod and a good ball joint,will the wheel shake back and forth,if its the wheel bearing or will it just make a noise or both,,cause i have a loose in the wheel and it isnt making any noise,,,i havnt had much experiance with this problem so i wouldnt know,,thanks,
Old May 3, 2007 | 10:15 PM
contagious19's Avatar
contagious19
Default RE: wheel bearing question?
if da wheel bearing was bad it would b makin a noise, it happened to me
Old May 3, 2007 | 11:58 PM
das2123's Avatar
das2123
Found on the net...
A bad wheel bearing will typically make grinding, whining or squealing noises, and you can often feel the looseness or roughness if you raise the suspension and rotate the wheel by hand. Worn wheel bearings should be replaced, because failure may cause the wheel to come off the vehicle.
Old May 4, 2007 | 12:18 AM
brute's Avatar
brute
Yes, the bad wheel bearing(s) will sound like your car is going to fall apart because it literally is about to. Here's the result of a bad wheel bearing... I hope you can tell which one is bad...
Old May 4, 2007 | 02:38 AM
johnneon's Avatar
johnneon
well mine isnt making any noises yet,,just have play on the wheel,,and its not the tie rod nor the ball joint,,it seems 2 me like its the wheel bearing!!but if its generally supposed to make a noise well,im not sure what else to check,if i push from side to side,and up and down i have the same play in the wheel,,and my tie rods new and my ball joint has no play what so ever,,so im confused,,
any ideas!!
Old May 4, 2007 | 10:28 AM
spudsterier's Avatar
spudsterier
sounds like your wheel bearing to me....
a bad bearing if cought in an early stage will only cause movement....no noise......
the noise will show up at a later date if the bearing goes unfixxed
though i have never had a bearing actually fall apart to where the wheel fell off...and ive driven on bad wheel bearings for more then 10,000 miles.....by the time i fixed it i had about 5 inches of back and forth play on the tire[&:]....but never fell off
personally i dont see how a wheel can fall off from a bad bearing....
Old May 4, 2007 | 11:36 AM
johnneon's Avatar
johnneon
great thanks for all your help!!!
im thinking that the bearing could be causing one of my problems,,like when istep on it,,the steering wheel goes right and the car pulls left,could that be the problem for that!!!!!!!thanks
Old May 4, 2007 | 04:01 PM
spudsterier
a bad wheel bearing will cause sloppy steering
Old May 4, 2007 | 04:08 PM
johnneon's Avatar
johnneon
cool thanks,,,
