HELP ASAP
Old May 4, 2007 | 03:48 PM
neonracer1010's Avatar
neonracer1010
Default HELP ASAP
ok so this morning i was driving and went to back into my parking spot at school and when i put the car in reverse it wouldnt move at all it was like neutral, and neutral is like drive and drive is like drive, and park is still like park always is. why would reverse not be working at all. its a 2nd gen automatic. i have no idea what it is
Old May 4, 2007 | 03:52 PM
johnneon's Avatar
johnneon
Default RE: HELP ASAP
ide say its time for a new tranny,but u could try checking the fluids but ide be suprised if its just the fluids,my dad had that happen to his car once and the tranny was finished??[&:]
good luck and keep us posted!!
Old May 4, 2007 | 04:08 PM
spudsterier's Avatar
spudsterier
maybe a problem with the linkage....
when you get home try to put the car up on jack stands....not to high though...
remove the tranny linkage from the trans.....
start the car and from under the hood, manually put it in each gear.....check and see how the tires are goin
atleast this will help you figureo ut if the problem is in the tranny or not
Old May 4, 2007 | 05:44 PM
neonracer1010
during lunch today i got it to go into reverse and everygear works properly now, except that it doesnt shift into third. could i reset the computer by unhooking the battery to get it to shift or is there something else that i could do. also when i take off its kinda jerky, and hesitates alot.
Old May 4, 2007 | 08:08 PM
neoncrazy101's Avatar
neoncrazy101
how is it a 2gen tranny? i thought the 2gen autos wouldn't fit the 1st gen?
Old May 4, 2007 | 09:07 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
linkage i would say
Old May 5, 2007 | 12:24 AM
spudsterier
maybe its from a 2000...then it would be the same
i dont think the computer would end up having anything to do with it shifting....but then again i dont really know automatics
is the linkage maybe binding suwhere?????
Old May 5, 2007 | 08:13 AM
DOHCgarrett t3
i would have to say the linkage came loose, it happend to my wife when we were in alaska.
we bought a car in alaska for 400 at an auction and it needed a new trans. we had it replaced and the retards that put it in must have been well retarted cause the linkage came loose after a week and now it leaks trans fluid like a sub with a screen door. i will never go there again.
Old May 5, 2007 | 11:35 AM
HabitatHxC's Avatar
HabitatHxC
When i was diagnosing my tranny with the tranny shop they said that if it was in neutral and it was like drive and it reverse was like neutral... then my clutches were welded together. and that it was time to rebuild.
Old May 5, 2007 | 04:34 PM
mmench's Avatar
mmench
wen i hd that problem my tranny was done for
