Front brakes sticking
Old May 4, 2007 | 09:13 PM
paxilman's Avatar
paxilman
Default Front brakes sticking
I'm having problems with my front brakes on my '98 Dodge Neon.....The front brakes were sticking......would get hot and smoke.....I was told that I should put new seals in the calipers......so I took the front left one off, and the piston was pretty well shot. So I put new calipers, pads, and rotors, on the front, blead them....and now it is doing the same thing. The left one seems to be worse. Once I use the brakes, they won't release all the way. After a few miles, they get very hot, and smoke. Does anyone have any ideas what the problem could be?????????.......Till I get it figured out, I've been using my emergency brakes to stop, wich is a big pain......Help me.....anyone??????
Old May 4, 2007 | 09:34 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Front brakes sticking
maybe a bad master cyclinder. maybe check the peddle and the linkages
Old Jun 17, 2007 | 11:42 AM
coey_78's Avatar
coey_78
Any other problems it could be?
Old Jun 17, 2007 | 12:41 PM
DOHCgarrett t3
are your brake lines pinched anywhere?
Old Jun 18, 2007 | 08:15 PM
MaverickH1's Avatar
MaverickH1
Brake lines could be contaminated. In which case you'd have to flush out all the fluid (which can be a PITA unless you have access to a pressure bleeder).
Old Jun 18, 2007 | 10:09 PM
DOHCgarrett t3
maybe unhook the brake lines from the calipers and pump them a lot and keep adding new fluid do one brake at a time.
Old Jun 18, 2007 | 10:31 PM
NEONRT98's Avatar
NEONRT98
Just replace the brake lines... If you disconnect the brakes and pump them, its like pumpnig the brakes with a bleeder valve open and your going to introduce air into the system and run into more problems
Old Jun 18, 2007 | 10:54 PM
DOHCgarrett t3
uhh wont replacing the lines be full of air anyways?
Old Jun 19, 2007 | 12:03 AM
coey_78's Avatar
coey_78
I cant see anywhere that the lines are pinched. It will pump brake fluid out with the bleeder valve open but once its closed it locks the piston in place and when the bleeder is opened again brake fluid shoots out and the piston is released. Could it be that Im not bleeding it correctly and there is air in it, but if its that, wouldnt all the brakes act up. Ive done quit a few brake jobs but this one leaves me puzzled. Its had two new calipers actually three altogether the original locked up put a new on and this started happening and i thought I got a bad one or something so I put this one on and the same thing happened. I dont know what to do next.
Old Jun 19, 2007 | 02:20 PM
bigwormskidoo's Avatar
bigwormskidoo
check the brake hoses, This just happened to me on my 99 r/t the drivers rear was sticking couldn't figure it out than found the brake hose had collapsed inside, outside looked brand new.
