dumb question
Old May 7, 2007 | 03:19 AM
loud99R/T's Avatar
loud99R/T
Default dumb question
kind of a dumb question but did all the r/t's have ABS brakes? or was that just an option?
Old May 7, 2007 | 04:35 AM
mr340's Avatar
mr340
Muscle Car Moderator
Default RE: dumb question
I believe it was an extra cost option, I have it on mine, but I don't have the original window sticker so I cant say positively.
Old May 7, 2007 | 09:54 AM
spudsterier's Avatar
spudsterier
2 of my last 3 r/t's didnt have abs....only 1 did
it was an option
Old May 8, 2007 | 03:06 AM
loud99R/T's Avatar
loud99R/T
how do i tell besides the pumping in the brake pedal?
Old May 8, 2007 | 10:13 AM
spudsterier
hwo do you tell what????
if you want to be able to tell if its got abs then usually the brake pedel will say abs on it, or you can pop the hood and look down at the master cylinder.....if the car has no abs then you will just see 4 brake lines comming out of the master cylinder.....if you have abs, then there will be a large square box below the master cylinder with about 8 brake lines going too it
Old May 8, 2007 | 05:24 PM
loud99R/T's Avatar
loud99R/T
lol i told you it was a dumb question
Old May 8, 2007 | 07:45 PM
spudsterier
no its an understandable question
Old May 9, 2007 | 02:52 AM
master tech's Avatar
master tech
Site Moderator & Tech
I belive if ordered a car withfourwheel disc it came with ABS.
Old May 9, 2007 | 10:08 AM
spudsterier
abs was only available on cars with rear disc brakes.....but was still an option
you can get a car with rear discs that didnt have abs
Old May 9, 2007 | 12:00 PM
das2123's Avatar
das2123
ORIGINAL: master tech
You are wrong then. You could order it without the crappy ABS system.
