HELP!!!!!!! car shakes
Old May 9, 2007 | 12:35 AM
flacoz_da_king's Avatar
flacoz_da_king
Default HELP!!!!!!! car shakes
help people just gotmy neonand it starts to shake after i hit 70 i do not know if that is normal
Old May 9, 2007 | 02:55 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: HELP!!!!!!! car shakes
You may what to have your tires balance.
Old May 9, 2007 | 11:47 AM
das2123's Avatar
das2123
ORIGINAL: flacoz_da_king
The whole car or just the steering wheel? The steering wheel shake is typical. Get the tires rebalanced to the nearest 1/8 ouce instead of 1/4 ounce.
Old May 9, 2007 | 01:19 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
there could be a few things that do this since you say 70mph i would rule out a bad tie rod either your tires are out of balance or the tred is "seperated" this happens when the car sits a long time in one spot or the tires are old and warn.
