woofer problem HELP!!!!!!
Old May 10, 2007 | 08:56 PM
flacoz_da_king's Avatar
flacoz_da_king
Default woofer problem HELP!!!!!!
i hooked my woofers in and they are on but they are making a buzzing noise anybody know the problem
Old May 10, 2007 | 08:57 PM
Kalevra's Avatar
Kalevra
Default RE: woofer problem HELP!!!!!!
just might be blown
Kalevra's Avatar
Kalevra
or set too high and on the verge of blowing
Old May 11, 2007 | 01:18 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
did you run your RCA and power wires side by side?
Old May 11, 2007 | 05:28 PM
loud99R/T's Avatar
loud99R/T
refresh me what are the rca wires?
Old May 11, 2007 | 06:18 PM
iwalton63's Avatar
iwalton63
they will look something like this.
Old May 12, 2007 | 02:25 AM
prplhaze's Avatar
prplhaze
Is the buzzing noise more like a whinning noise...that changes with the engine? If that's the case you need a better ground connection to amp. Do the subs still bump when you turn them up.? You really have'nt told us much...
Also I have never heard "on the verge of blowing" a voice coil is either good, or it's not.If it scratches when you press on the woofer, it's no good.
Old Jul 29, 2007 | 12:06 AM
flacoz_da_king
thnx fer all help i bought new ground wire
